Edge Transit Gateway Deployment Workflow on Megaport Virtual Edge
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Transit Gateways on Megaport Virtual Edge.
Edge Transit Gateway on Megaport Virtual Edge is available as a Preview Feature in CoPilot version 4.14 with Controller version 7.2.4820. |
The following diagram shows an example of network connectivity for Edge Transit Gateway to a Transit Gateway in AWS. This topology shows Edge Transit connection to an upstream WAN router which is used to terminate CSP underlay private connections.
The topology below shows Edge Transit Gateway used to terminate CSP underlay private connections (which does not require upstream WAN router).
Edge Transit Gateway requires the latest versions of Aviatrix Controller 7.2 and Aviatrix Edge Image 7.2 to support BGP underlay connectivity to CSP. |
Before you can deploy an Edge Transit Gateway on the Megaport platform, you must perform the prerequisite steps to set up an Equinix account, a Network Service Provider (NSP) platform account, and provide network access.
For instructions to create these accounts, see Prerequisites for Edge Transit Gateway Deployment on Megaport Virtual Edge.
Edge Transit Gateway Deployment Workflow in Megaport
To deploy an Edge Transit Gateway, first you need to procure and onboard your edge devices on the platform of your choice (see Prerequisites for Edge Transit Gateway Deployment on Megaport Virtual Edge.
Next, you deploy the primary and secondary highly available (HA) Edge Transit Gateways on the edge devices. Then, attach the primary Edge Transit Gateway to the Aviatrix Transit Gateway for cloud connectivity and to the Edge Spoke Gateway for LAN-side connectivity. The workflow below guides you through these steps.
Creating the ZTP Cloud-Init for the Primary Edge Transit Gateway (Megaport)
The Edge Gateway cloud-init ZTP file is used to provision the Edge Gateway virtual machine and create the Edge Gateway in Megaport Virtual Edge (MVE).
To create the primary Edge Transit Gateway cloud-init ZTP file, follow these steps.
Step 1: Gateway Configuration
Click Transit Gateways, then click + Transit Gateway and provide the following information.
You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. See Setting up Accounts for Edge Platforms.
Identifies the edge location.
You can select an existing name or enter a new name for the edge location. See Edge site.
ZTP File Type
This is set to cloud-init.
By default, an Edge Transit Gateway has two interfaces: one WAN interface on eth0, and one Management interface on eth2. You can configure multiple WAN interfaces on the Edge Gateway, as needed. You will need these configuration information to configure the interfaces.
In the Interface Configuration, configure the WAN and Management interfaces for the Edge Transit Gateway.
Configure the WAN Interface
You can configure up to 9 WAN interfaces on the Edge Transit Gateway.
In Interface Configuration, click + WAN Interface and provide the following information.
Interface Secondary CIDRs
The Local ASN Number of the Edge Gateway.
Password (optional)
The MD5 authentication key.
To configure the Edge Transit Gateway Management interface:
In Interface Configuration, click MGMT > + MGMT Interface.
Leave the Private Network setting to Off. In Megaport, the MGMT interface of the Edge Transit Gateway is assigned the public IP address that is allocated by Megaport.
Step 3: Interface Mapping
The Interface Mapping shows how the Edge Gateway’s logical interface names maps to the Edge Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. The mapping is provided for your reference when performing any diagnostic or troubleshooting on the Aviatrix Platform.
Field |
Description |
Interface |
Click Done to create the ZTP cloud-init image file. CoPilot downloads the ZTP cloud-init file to your downloads folder.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on your Equinix platform within that time. You will not be able to download the cloud-init file again and will have to recreate a new file. |
Creating the ZTP Cloud-Init for the Secondary Edge Transit Gateway (Megaport)
To create the secondary HA Edge Transit Gateway, first you need to set the high availability mode for the primary Edge Transit Gateway, then configure the secondary HA gateway settings. The workflow below guides you through these steps.
Step1: Set the Primary Edge Gateway High Availability Mode
Click Transit Gateways.
In the table, locate the primary Edge Transit Gateway for which you want to create the HA gateway and click its Edit icon.
In Gateway Configuration, from the High Availability dropdown menu, select Active-Active mode.
Click Next and configure the gateway interfaces.
Step 2: Configure the Secondary Edge Gateway Interfaces
In Interface Configuration, configure the WAN and Management interfaces for the secondary Edge Gateway.
Configure the WAN Interfaces
To configure the secondary Edge Gateway’s WAN interfaces:
In Interface Configuration, provide the following information.
Password (optional)
To configure the secondary Edge Transit Gateway Management interface:
In Interface Configuration, click MGMT.
Leave the default settings and click Next.
Field |
Description |
Interface |
In Backup Peering:
Select a WAN interface to use to establish the attachment peering between the primary and HA Edge Transit Gateway.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on your Megaport platform within that time. You will not be able to download the cloud-init file again and will have to recreate a new file. |
Transit Gateway
Local Edge Gateway Interface
Attach Over
Number of Tunnels
Excluded Network CIDRs
If you want to use Jumbo Frames for the attachment peering connection between the Edge Gateways, make sure to enable Jumbo Frames on the Edge Gateways before you create the attachment. |
Spoke Gateway
Remote Edge Gateway Interface
Attach Over
Number of Tunnels
Parameter Description Name
Connect Local Gateway To
