Monitoring Health of Edge Devices
If you use Aviatrix Secure Edge for your edge locations, you can monitor system and network telemetry statistics for your Edge devices.
CoPilot shows the following device health information as reported by each Edge device.
System statistics for each Edge device:
  • CPU Usage — The percentage of CPU used
  • Memory Usage — The percentage of memory used
  • Disk Usage — The percentage of disk used
Network throughput for each Edge device for each physical interface:
  • The number of bytes transmitted
  • The number of bytes received
To monitor system and network telemetry statistics for your Edge devices, do the following:
  1. Log in to CoPilot.
  2. Go to the CoPilot > Cloud Fabric > Edge > Devices page.
  3. Click on the name of the device to view telemetry statistics.
  4. Open the System Metrics or Network Metrics tab to show system or network telemetry statistics.
  5. In the details pane, use the date and time picker to set the timeframe for viewing historical telemetry statistics for the device.
