Edge Spoke Gateway Deployment Workflow on Megaport Virtual Edge
Aviatrix Edge on Megaport Virtual Edge is available as a Preview Feature in CoPilot version 4.11 with Controller version 7.1.3958. |
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on Megaport Virtual Edge.
The design below shows a high-level hybrid cloud solution with Aviatrix Edge leveraging Megaport fabric.
Before you deploy an Aviatrix Edge Gateway on the Megaport Virtual Edge platform, you must perform the prerequisite steps to set up a Megaport Portal account and a Network Service Provider Platform account.
For instructions on how to create these accounts, see Prerequisites for Edge Spoke Gateway Deployment on Megaport Virtual Edge.
Aviatrix Edge Spoke Gateway Deployment Workflow in Megaport
To deploy Aviatrix Edge Spoke Gateway, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Edge Spoke Gateway Deployment on Megaport Virtual Edge). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in Megaport Virtual Edge. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
Creating the ZTP Cloud-Init for the Primary Edge Gateway
The Edge Gateway cloud-init ZTP file is used to provision the Aviatrix Edge Gateway virtual machine and create the Edge Gateway in Megaport Virtual Edge (MVE).
To create the Edge Gateway cloud-init ZTP file, follow these steps.
In CoPilot, go to Cloud Fabric > Edge > Gateways tab.
Click + Gateway, then provide the following information.
You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Edge > Platforms tab (see Set Up the Network Service Provider Platform Account).
ZTP File Type
This is set to cloud-init.
Deploying multiple Edge Gateways for the same site is supported. A maximum of 16 Edge Gateways is supported.
By default, an Aviatrix Edge Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, LAN, and MGMT), additional two interfaces can be WAN interfaces.
This is set to eth0.
Adding multiple WAN interfaces is applicable when Edge Gateway is used for BGP underlay to CSP. Add an interface per CSP underlay (such as Direct Connect or Express Route). Aviatrix recommends a maximum of 4 WAN interfaces per Edge Gateway. When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router.
Enables BGP connection on the WAN interface when set On.
WAN support for BGP underlay to CSP is supported for AWS and Azure. Interface CIDR
Parameter Description Link-Local Underlay CIDR (GCP only)
The Link-Local Underlay CIDR is used for High Performance Encryption (HPE) peering connections when the WAN interface CIDR is a link-local address (address is in the range 169.254.0.0 to 169.254.255.255) and BGP is set to On.
When BGP is set to On, the WAN interface link-local address is not propagated to the Cloud Service Provider (CSP) routing table. In this case, the Link-Local Underlay CIDR is used to establish the HPE peering connections.
The Link-Local Underlay CIDR cannot be a link-local address. Local ASN
The ASN of the Edge Gateway.
Password (optional)
The MD5 authentication key.
To change or update the Edge Gateway WAN connectivity to Transit Gateway, you will need to first detach the Edge-to-Transit gateway attachment, if there is an attachment. |
Next, configure the LAN interface.
Configuring the LAN Interface
Click + LAN Interface, then provide the following information.
This is set to eth1.
Next, configure the MGMT interface.
Click + MGMT interface. Leave the default settings.
Leave the Private Network setting to Off. In the Megaport Fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
If a required field is missing, the respective interface tab is highlighted to indicate there is an error.
The cloud-init image file expires after 24 hours. You cannot download it again and will have to repeat the above steps to recreate the file. You must launch an Edge MVE on the Megaport platform and deploy the Edge Gateway within the 24 hours. See Launching the Edge Gateway in Megaport Virtual Edge.
Creating the ZTP Cloud-Init for the Secondary Edge Gateway (Megaport)
To create a highly available (HA) Edge Gateway, follow these steps.
Configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, MGMT and LAN), additional two interfaces can be WAN interfaces.
Password (optional)
Alternative HA Configuration
You can also deploy Edge Gateways in the same site which allows additional Edge Gateways to be deployed in the same site to act in the A/A mode. This is also called horizontal scaling mode.
To deploy additional Gateways, following the same workflow as primary gateway, select the same site as the first gateway and leave the HA option off.
To launch the Aviatrix Edge Gateway in Megaport Virtual Edge (MVE), you must log in to your Megaport Portal to create the MVE and specify the cloud-init file for the Edge Gateway creation and create a Megaport Internet connection for the Management interface for the Edge Gateway authentication with the Aviatrix Controller. For instructions on how to create the MVE and Megaport Internet connection, see Aviatrix with Megaport Virtual Edge in the Megaport documentation.
You will need to create Megaport Internet VXC and attach to the eth2 interface of the Edge Gateway to allow the Edge Gateway access to the Aviatrix Controller. |
Once the Aviatrix Edge MVE is created and provisioned, to complete the Edge Gateway authentication with the Aviatrix Controller, you must configure the Edge Gateway Management Egress IP address .
The Management Egress IP address of the Aviatrix Edge Gateway virtual device must be updated from the Aviatrix CoPilot so that the Security Group of the Aviatrix Controller is updated with the correct Egress IP address.
Locate the public IP assigned by Megaport after Internet VXC is attached to the Aviatrix Edge Gateway eth2 interface.
From Megaport Portal, go to Internet VXC attached to the Edge Gateway.
Click on the VXC Details and note down the public IP address (IPV4).
In Aviatrix CoPilot, navigate to Cloud Fabric > Edge > Gateways tab.
Update the Egress CIDR with the Public IP of the Edge Gateway VM from the Megaport VXC Details. Use public IP/32 format, for example 162.43.142.19/32.
Before you attach the Edge Gateway to the Transit Gateway, ensure the Local ASN Number is configured on both gateways.
You can attach an Edge Gateway to multiple Transit Gateways. Each attachment can be configured over the preferred WAN interface, connection over private VXC or public network, high-performance encryption, and Jumbo Frame.
Connecting Edge Interfaces
Multiple WAN interfaces is supported.
If the Edge WAN connection to the Transit Gateway is over a private network, set this toggle to On. For private VXC, this should be On.
For HPE over private network, setting number of tunnels count to 0 creates maximum tunnels based on the peering gateway size.
Parameter Description Name
Connect Local Gateway To
