Aviatrix Controller Diagnostics
You can run diagnostics in CoPilot for your Aviatrix Controller instance.
In CoPilot, go to Diagnostics > Diagnostic Tools > Controller Diagnostics.
On the Controller Diagnostics page, select a tool from the Tools list and click Run, where appropriate.
To copy the report content, move your cursor over the output and click Copy to Clipboard.
| Controller Diagnostics Tool | Description | ||
Ping |
Run ping from the Controller virtual machine. Type the IP address or host name of the host and click Run. |
Services |
Run brief or extended diagnostics for CLOUDXD. Restart any of the services (CLOUDXD, PERFMON, PKI, RSyslog, GlobalConfigDB, MongoDB, ConduitDaemon).
Command Log |
View Controller command logs. Click Refresh to refresh the latest logs. |
Event Log |
View Controller event logs by event type. Click Refresh to refresh to the latest logs. |
Diagnostics |
Run a comprehensive diagnostics report that you can download and analyze or send to Aviatrix support. Provides details on routes, NTP, DNS, SSH, IPsec, and other services operating on the gateway to aid in identifying active or inactive services. |
