Configuring BGP Connection Settings
You configure a gateway’s BGP connection settings in the gateway’s Settings tab in Aviatrix CoPilot.
  1. To configure BGP settings:
    • For Transit or Spoke Gateway, go to CoPilot > Cloud Fabric > Gateways > Transit Gateways or Spoke Gateways tab.
    • For Edge Gateway, go to CoPilot > Cloud Fabric > Edge > Gateways tab.
  2. In the table, select the gateway for which you want to enable BGP features.
  3. Click the gateway’s Settings tab.
  4. In the Settings tab, expand the BGP section.
  5. Enable the gateway’s BGP settings as needed.
