Prerequisites for Edge Transit Gateway Deployment on Megaport Virtual Edge
The following are the prerequisites to deploy an Aviatrix Edge Transit Gateway on Megaport Virtual Edge.
1. Obtain a Megaport Portal Account
If you do not already have a Megaport Portal account, refer to Creating an Account in the Megaport documentation.
2. Set Up the Network Service Provider Platform Account
To deploy Aviatrix Edge Gateways on Megaport Virtual Edge, you will need to first set up a Network Service Provider platform account in CoPilot.
3. Provide Network Access
Aviatrix Edge Gateway requires outbound access to communicate with the Aviatrix Controller, Aviatrix CoPilot, and other Aviatrix Gateways. You must allow access on the specified ports on your firewall.
4. Obtain Edge Gateway Interface Configurations
The Edge Transit Gateway on Megaport Virtual Edge supports one Management and up to 9 WAN interfaces.
For each WAN interface that you want to configure, you will need to provide the following information during Edge Gateway creation for your primary and secondary HA Edge Gateways.
WAN Interface
Interface Primary CIDR
Interface Secondary CIDRs
Secondary CIDR cannot be link-local CIDR.
If you need to setup BGP underlay connection to the Cloud Service Provider (CSP), you will need to provide the following information.
BGP Configuration
For the Management interface, you will need the Egress IP.
Management Interface
Egress CIDR (Primary)
This is the public IP of the Edge VM assigned by Megaport, which can be obtained once Megaport Internet VXC is connected to the MGMT interface of the Edge Gateway. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway.
Egress CIDR (Secondary)
The Egress public IP for the secondary Edge Gateway’s Management interface when High Availability is configured.
