Edge Spoke Gateway Horizontal Scaling
This document provides a brief overview of Edge Spoke Gateway horizontal scaling.
Edge Spoke Gateway horizontal scaling provides you the flexibility to add or remove gateways to plan for capacity during peak times to ensure high availability and improve and maintain network stability and performance.
Edge Spoke Gateway horizontal scaling is supported only with the latest version of the Aviatrix Controller. |
Horizontal scaling requires all Edge Spoke Gateways in an xref:edge-gateway-settings.adoc#site[edge site to be deployed in active-active mode. A maximum of eight Edge Spoke Gateway instances are supported per site.
Edge Spoke Gateways can be scaled horizontally and peered to the Transit Gateway or Edge Transit Gateways across single or multiple clouds and regions.
The Edge Spoke Gateways connects to the Transit Gateways and Edge Transit Gateways with active peering connections. Network traffic between the Transit Gateways and Edge Spoke Gateways or between Edge Transit Gateways and Edge Spoke Gateways is load balanced and forwarded across all active peering connections by using Equal Cost Multi Path (ECMP) routing.
The following figure shows multiple Edge Spoke Gateways deployed in the same edge site for horizontal scaling with multiple active-active connections for multicloud to edge connectivity.
The example below shows an Edge configuration in CoPilot with four Edge Gateway instances in active-active high availability mode for the same edge site for horizontal scaling.
When a high availability mode is not selected, Edge Gateways deployed in the same edge site default to active-active mode.
For more information about creating HA Edge Gateways, see About Creating Highly Available Edge Gateways.
