Resizing Gateways Based on Auto Right-Sizing Recommendations
Aviatrix recommends performing auto right-sizing during gateway maintenance periods. |
After clicking Resize next to a gateway instance on the Auto Right-Sizing tab (or on a gateway instance’s Details page), you can go to the Events tab to monitor the status of the recommendation.
The following statuses are possible for recommendations:
In Progress: the auto right-sizing recommendation is in progress.
Success: the auto right-sizing recommendation was implemented successfully.
Error: the auto right-sizing recommendation was not implemented successfully. Hover over the tooltip next to the status to see the error. You can go to the Monitor > Notifications > Tasks tab to see more details on the error.
If a resize fails, the gateway recommendation should become visible again on the Auto Right-Sizing tab if it is still within the same monitoring period, to allow you to try again. If a new monitoring period has started, the latest data will be used to determine whether the recommendation should display.
