Edge Transit Gateway Deployment Workflow for On-Premises
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Transit Gateways on the Aviatrix Edge platform.
Before you can deploy an Edge Transit Gateway on the Aviatrix Edge Platform:
You must perform the prerequisite steps to procure and onboard your edge device. See Prerequisites for Edge Transit Gateway Deployment for On-Premises.
Aviatrix Edge Transit Gateway Deployment Workflow
To deploy an Edge Transit Gateway, first you need to procure and onboard your edge devices on the platform of your choice (see Prerequisites for Edge Transit Gateway Deployment on Equinix Network Edge.
Next, you deploy the primary and secondary highly available (HA) Edge Transit Gateways on the edge devices. For cloud connectivity, attach the primary Edge Transit Gateway to the Aviatrix Transit Gateway. For LAN-side connectivity, attach the primary Edge Transit Gateway and the Edge Spoke Gateway.
The workflow below guides you through these steps.
Creating the Primary and Secondary Edge Transit Gateway (Aviatrix Edge Platform)
To create a primary and secondary (HA) Edge Transit Gateway, follow these steps.
Step 1: Gateway Configuration
Click + Transit Gateway, then provide the following information.
You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. See Set Up the Aviatrix Edge Platform Account.
Identifies the edge location.
The high availability mode.
Preemptive
Determines the network’s behavior when the primary gateway goes down.
Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
Primary Device
Secondary Device
The gateway size.
Small - 2 vCPU - 4GB
Medium - 4 vCPU - 8GB
Large - 8 vCPU - 16GB
X-Large - 16 vCPU - 32GB
By default, an Edge Transit Gateway has two interfaces: one WAN interface on eth0 and one Management interface on eth2. You will need these configuration information to configure the interfaces.
In the Interface Configuration section, configure the WAN and Management interfaces. If High Availability mode is selected, then configure both the primary and secondary Edge Gateways.
For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is. |
Configure the WAN Interface
You can configure up to 4 WAN interfaces for the primary Edge Gateway.
Interface
IP Assignment
Interface Secondary CIDRs
The Local ASN Number of the Edge Gateway.
Password (optional)
The MD5 authentication key.
In Interface Configuration, click MGMT, then provide the following information.
IP Assignment
The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge platform. This setting cannot be changed.
Egress CIDR (Primary)
If the public IP is used from Edge Gateway Management interface to establish connectivity to Aviatrix Controller, then configure the public IP as the CIDR. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway.
Egress CIDR (Secondary)
The Egress public IP for the secondary Edge Gateway’s Management interface when High Availability is configured.
Step 3: Interface Mapping
The Interface Mapping shows how the Edge Gateway’s logical interface names maps to the Edge Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. The mapping is provided for your reference when performing any diagnostic or troubleshooting on the Aviatrix Platform.
Field |
Description |
Interface |
If the Edge Gateway is deployed in Active-Active high availability mode:
In Backup Peering, select a WAN interface to use to establish the attachment peering between the primary and HA Edge Gateway.
Click Done to create the primary and HA gateways.
Field |
Description |
Name |
Name for the Edge Gateway. The name must start with a letter and contain only letters, numbers, and dashes (no special characters or spaces) and it can be up to 50 characters long. |
Platform |
The platform account where you want to deploy the Edge Gateway. You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. |
Site |
Identifies the edge location. You can select an existing name or enter a new name for the edge location. |
High Availability |
Preemptive |
Determines the network’s behavior when the primary gateway goes down. Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
Primary Device |
The edge device where you want to deploy the primary Edge Gateway. |
Secondary Device |
Gateway Resource Size |
The gateway size.
For IP settings, use the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 to indicate the netmask. |
WAN Interface
Field |
Description |
IP Assignment |
The default is Static for static IP assignment. DHCP for dynamic IP address assignment is not supported. |
Interface Labels |
Name to identify the WAN interface. |
BGP |
Enables BGP underlay connection to cloud service provider (CSP) on the WAN interface. Set BGP toggle On to set up BGP connection to cloud routers such as VGW, VNG, and Google cloud router.
Interface Primary CIDR |
The CIDR for the WAN interface. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24).
If you need to create a BGP underlay connection to cloud service provider (CSP) with a link-local IP address, you must enter the link-local IP address in the Link-local Underlay CIDR setting of the WAN interface. |
Interface Secondary CIDRs |
The secondary CIDRs for the WAN interface. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24). The secondary CIDRs are used for High Performance Encryption (HPE) attachment peering connections over a private network between the Edge Transit Gateway to another Edge Transit Gateway or Edge Spoke Gateway. The secondary IP addresses (based on the secondary CIDRs) are automatically assigned to create the peering connections. You can define /32 CIDR for specific secondary IP address.
Default Gateway IP |
Public IP |
WAN BGP
Field |
Description |
Local ASN |
The Local AS Number of the Edge Gateway. |
Remote ASN |
The AS Number of the CSP side peering connection such as private VIF on VGW (AWS) and VNG ASN (Azure). |
Local Tunnel IP |
The IP address of the Edge Gateway. This is the local peering PTP IP for BGP. |
Remote Tunnel IP |
The IP address of the CSP VNG or VGW peering PTP IP. (GCP is not supported). |
Password (optional) |
The MD5 authentication key. |
MGMT Interface
Field |
Description |
IP Assignment |
The MGMT interface defaults to DHCP. The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge platform. This setting cannot be changed. |
Egress CIDR (Secondary) |
The Egress public IP for the secondary Edge Gateway’s Management interface when High Availability is configured. |
If a required field is missing, the interface tab is highlighted to indicate there is an error. |
Interface Mapping
The Interface Mapping shows how the Edge Gateway’s logical interface names maps to the Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. The mapping is provided for your reference when performing any diagnostic and troubleshooting on the Aviatrix Platform.
Field |
Description |
Interface |
Transit Gateway
Local Edge Gateway Interface
Attach Over
Number of Tunnels
Excluded Network CIDRs
If you want to use Jumbo Frames for the attachment peering connection between the Edge Gateways, make sure to enable Jumbo Frames on the Edge Gateways before you create the attachment. |
Spoke Gateway
Remote Edge Gateway Interface
Attach Over
Number of Tunnels
Parameter Description Name
Connect Local Gateway To
