Edge Spoke Gateway Deployment Workflow on Equinix Network Edge
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on the Equinix Network Edge.
The following diagram shows an example of network connectivity for Aviatrix Edge Spoke Gateway to Transit Gateway in AWS. This topology shows Aviatrix Edge Spoke Gateway connection to an upstream WAN router which is used to terminate CSP underlay private connections.
The topology below shows Aviatrix Edge Spoke Gateway used to terminate CSP underlay private connections (which does not require upstream WAN router).
Aviatrix Edge Spoke Gateway requires the latest versions of Aviatrix Controller 7.1 and Aviatrix Edge Image 7.1 to support BGP underlay connectivity to CSP. |
Before you can deploy an Aviatrix Edge Spoke Gateway on the Equinix platform, you must perform the prerequisite steps to set up an Equinix account, a Network Service Provider (NSP) platform account, and provide network access.
For instructions to perform these prerequisite steps, see Prerequisites for Edge Spoke Gateway Deployment on Equinix Network Edge.
Aviatrix Edge Spoke Gateway Deployment Workflow in Equinix
To deploy Aviatrix Edge Spoke Gateway, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Edge Spoke Gateway Deployment on Equinix Network Edge). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in Equinix Network Edge. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
Creating the ZTP Cloud-Init for the Primary Edge Spoke Gateway (Equinix)
The Edge Gateway cloud-init ZTP file is used to provision the Edge Gateway virtual machine and create the Edge Gateway in Equinix Fabric.
To create the primary Edge Spoke Gateway cloud-init ZTP file, follow these steps.
Click Spoke Gateways, then click + Spoke Gateway and provide the following information.
You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. See Set Up the Aviatrix Edge Platform Account.
Identifies the edge location.
You can select an existing name or enter a new name for the edge location. See Edge site.
ZTP File Type
This is set to cloud-init. See Edge Spoke Gateway High Availability.
By default, an Edge Spoke Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2. You can configure multiple WAN interfaces on the Edge Gateway, as needed. You will need these configuration information to configure the interfaces.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. While up to 8 WAN interfaces is supported, Aviatrix recommends a maximum of 4 WAN interfaces per Edge Gateway.
Interface
Adding multiple WAN interfaces is applicable when Edge Gateway is set up for BGP underlay to CSP. Add an interface per CSP underlay (such as Direct Connect or Express Route). A maximum of 8 WAN interfaces per Edge Gateway is supported. When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router.
IP Assignment
Local Tunnel IP
Remote Tunnel IP
Password (optional)
The MD5 authentication key.
Configuring the LAN Interface
To configure the Edge Gateway LAN interface, click + LAN Interface, then provide the following information.
Field |
Description |
Interface |
The Edge Gateway’s logical interface name. This is set to eth1. |
Interface Labels |
Name to identify the LAN interface. |
Interface CIDR |
The CIDR for the LAN interface. |
Default Gateway IP |
Click MGMT, then click + MGMT Interface.
Leave the Private Network setting to Off. In the Equinix Platform, the Management interface of the Edge Gateway is assigned the public IP address that is allocated by Equinix.
CoPilot downloads the ZTP cloud-init file to your downloads folder.
Next, log in to your Equinix Portal and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on the Equinix platform within that time. You will not be able to download the file again and will have to repeat the steps to recreate a new cloud-init file. See Launching the Edge Gateway in Equinix Network Edge.
Gateway Configuration
Field |
Description |
Name |
Name for the Edge Gateway. The name must start with a letter and contain only letters, numbers, and dashes (no special characters or spaces) and it can be up to 50 characters long. |
Platform |
The platform account where you want to deploy the Edge Gateway. You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. |
Site |
Identifies the edge location. You can select an existing name or enter a new name for the edge location. |
ZTP File Type |
This is set to cloud-init. |
WAN Interface
Field |
Description |
Interface |
When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router. |
Interface Labels |
Name to identify the WAN interface. |
BGP |
Enables BGP underlay connection to cloud service provider (CSP) on the WAN interface. Set BGP toggle On to set up BGP connection to cloud routers such as VGW, VNG, and Google cloud router.
Interface Primary CIDR |
The CIDR for the WAN interface. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24).
If you need to create a BGP underlay connection to cloud service provider (CSP) with a link-local IP address, you must enter the link-local IP address in the Link-local Underlay CIDR setting of the WAN interface. |
WAN BGP
Field |
Description |
Local ASN |
The Local AS Number of the Edge Gateway. |
Remote ASN |
The AS Number of the CSP side peering connection such as private VIF on VGW (AWS) and VNG ASN (Azure). |
Local Tunnel IP |
The IP address of the Edge Gateway. This is the local peering PTP IP for BGP. |
Remote Tunnel IP |
The IP address of the CSP VNG or VGW peering PTP IP. (GCP is not supported). |
Password (optional) |
The MD5 authentication key. |
LAN Interface
Field |
Description |
Interface |
Interface Labels |
Interface CIDR |
MGMT Interface
Field |
Description |
Interface |
This is set to eth2. |
Private Network |
Leave this setting to Off. In the Equinix Platform, the MGMT interface of the Edge Transit Gateway is assigned the Public IP address that is allocated by Equinix. |
Egress CIDR (Optional) |
The CIDR range for the egress for this Management interface. |
Creating the ZTP Cloud-Init for the Secondary Edge Gateway (Equinix)
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
WAN Interface
This is set to eth0.
WAN support for BGP underlay to CSP is supported for AWS and Azure. Interface CIDR
The WAN interface’s egress Public IP address.
The ASN of the Edge Gateway.
Local Tunnel IP
Remote Tunnel IP
Password (optional)
To change or update the Edge Gateway WAN connectivity to Transit Gateway, you will need to first detach the Edge-to-Transit gateway attachment, if there is an attachment. LAN Interface
For BGP over LAN, set this switch to turn BGP mode On.
Management Interface
Leave the Private Network setting to Off. In the Equinix Platform, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Equinix.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM on Equinix platform within that time, as you cannot download it again and will have to recreate the cloud-init file.
Deploying the Edge Gateway in Equinix Network Edge
To launch the Aviatrix Edge Gateway in Equinix Network Edge, see Create an Aviatrix Edge in the Equinix documentation. Demo video: Step-by-Step Guide to Deploy Aviatrix Secure Edge on Equinix Network Edge on Vimeo.
You will need to create an Access Control List Template to allow CoPilot access to the Aviatrix Edge virtual device. |
Once the Aviatrix Edge virtual device is created and provisioned, an email is sent to the notification email you provided informing that the Aviatrix Edge virtual device is provisioned.
Creating the Access Control List Template for CoPilot
The Access Control List Template defines the inbound rules for the Aviatrix Edge Gateway virtual device to allow specific inbound traffic. Aviatrix Controller and CoPilot needs to communicate with the Aviatrix Edge Gateway. Inbound traffic from the Controller and CoPilot must be allowed on the Edge Gateway virtual device.
Controller’s IP address will be automatically allowed based on the cloud-init. |
To define the inbound rules for CoPilot, in the CreateNew Access Control List Management Template page, provide the following information.
In the Basic Details section, enter a name for the Access Control List template and a description.
In the Inbound Rules section, enter the following information:
For IP Address Subnet, enter the CoPilot public or private IP address.
For Protocol, select IP from the drop-down.
For Description (Optional), enter a description for this rule.
Click Add Rule.
To create the Access Control List template, click Create Template.
The Management Egress IP address of the Aviatrix Edge Gateway virtual device must be updated from the Aviatrix CoPilot so that the Security Group is updated with the correct Egress IP address.
Locate the public IP assigned by Equinix during Aviatrix Edge virtual device creation.
From Equinix Fabric Portal, go to Network Edge > Virtual Device Inventory > Details and locate the Public IP address of the device.
In Aviatrix CoPilot, navigate to Cloud Fabric > Edge > Gateways tab.
Update the Egress CIDR with the Public IP from the Equinix Fabric Portal.
Before you attach the Edge Gateway to the Transit Gateway, ensure the Local ASN Number is configured on both gateways.
Connecting Edge Interfaces
Multiple WAN interfaces is supported.
High Performance Encryption
For HPE over private network, setting number of tunnels count to 0 creates maximum tunnels based on the peering gateway size.
Parameter Description Name
Connect Local Gateway To
