Ignoring Auto Right-Sizing Recommendations
If you choose to ignore a recommendation, you will not see it again unless you remove it from the Excluded VPC/VNets list in the Auto Right-Sizing Settings.
You can ignore any recommendations on the Auto Right-Sizing tab by:
  • Clicking the vertical ellipsis next to the gateway instance and selecting Ignore Recommendations from this VPC/VNet. Click Ignore when prompted.
  • Selecting one or more gateway instances and click Ignore Recommendations from VPC/VNets in the Actions menu. Click Ignore when prompted.
  • Clicking a gateway instance to see the details. Click Resize > Ignore Recommendations from this VPC/VNet.
    These actions add the VPC/VNet to the Excluded VPC/VNets list in Auto Right-Sizing Settings.
    If you no longer want to ignore the VPC/VNet, open Auto Right-Sizing Settings and remove it from the Excluded VPC/VNets list. Click Save.
