Dismissing Auto Right-Sizing Recommendations
You can dismiss an auto-sizing recommendation for the current monitoring period by doing one of the following on the Auto Right-Sizing tab:
  • Clicking the vertical ellipsis next to the gateway instance and selecting Dismiss Recommendation. Click Dismiss when prompted.
  • Selecting one or more gateway instances and clicking Dismiss Recommendations in the Actions menu. Click Dismiss when prompted.
  • Clicking a gateway instance to see the details, and then click Resize > Dismiss Recommendation.
Dismissed recommendations may display again during the next monitoring period. You can choose to ignore recommendations if you do not want them to display in subsequent monitoring periods.
