Prerequisites for Edge Spoke Gateway Deployment for On-Premises
The following are the prerequisites to deploy an Aviatrix Edge Gateway for on-premises on the Aviatrix Edge platform.
1. Procure the Edge Hardware
If you do not already have your edge hardware, you need to evaluate the hardware that you require for your edge computing and procure the hardware. Contact your Aviatrix account manager for the hardware you may require.
For a list of Aviatrix supported hardware appliances, see Supported Edge Hardware for the Aviatrix Edge Platform.
2. Obtain the Hardware Serial Number
To register edge hardware with the Aviatrix Edge platform, you will be required to provide the hardware serial number. Obtain the serial numbers for your edge hardware.
3. Set Up the Aviatrix Edge Platform Account
To onboard and register the edge hardware appliance with the Aviatrix Controller, you will need to first set up an Aviatrix Edge Platform Account.
4. Onboard the Edge Hardware
You must onboard and register the edge hardware appliance with the Aviatrix Controller, before you can deploy an Edge Gateway on the edge hardware.
5. Obtain Edge Gateway Interface IP Configurations
Setting Description
WAN Interface IP/Mask
The WAN IP address.
WAN Default Gateway
LAN Interface IP/Mask
The LAN IP address.
LAN Default Gateway
The Default Gateway IP address for the LAN interface.
Management Interface IP/Mask
The MGMT interface defaults to DHCP. This setting cannot be changed.
The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge Platform.
Management Default Gateway
The MGMT interface defaults to DHCP on the Aviatrix Edge Platform and cannot be changed.
Management Egress IP
The Management Egress IP address to be allowed in the Controller Security Group.
VRRP
The VRRP IP address.
Not required if not using VRRP.
VRRP can be configured only if HA gateway is configured.
VLAN ID
The VLAN ID for each VLAN segment.
VLAN IP
The VLAN IP address for each VLAN segment.
VLAN Default Gateway
The Default Gateway IP address for each VLAN segment.
6. Provide Network Access
Aviatrix Edge Gateway requires outbound access to communicate with the Aviatrix Controller, Aviatrix CoPilot, and other Aviatrix Gateways. You must allow access on the specified ports on your firewall.
