You must have port 443 open to the IP address of the Aviatrix Controller. For the required port access for Edge Gateway deployment, refer to Aviatrix Edge Gateway Ports and Protocols.
  1. Go to Cloud Fabric > Edge > Gateways tab.
  2. Click + Edge Gateway, then provide the following information.
    Select edge_admin.
    ZTP File Type
    Select the ZTP file type.
    • For VMware ESXi, select iso.
    • For KVM, select iso or cloud-init.
  3. Configure the WAN, LAN, and Management interfaces.
Configuring the WAN Interface
For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is.
Parameter Description
IP Assignment
(optional) A name to identify the WAN interface.
(optional) The Public IP address of the WAN interface.
Configuring the LAN Interface
IP Assignment
VRRP
If you have Virtual Router Redundancy Protocol (VRRP) configured for the LAN router redundancy, set this switch to On.
VRRP Gateway IP
The Virtual IP (VIP) address, when VRRP is enabled.
(optional) The Default Gateway IP for the LAN interface.
(optional) A name to identify the LAN interface.
VLAN Interface
You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration.
This is the interface where the untagged packets are sent.
VRRP Gateway IP
(optional) A name to identify this native VLAN interface.
VLAN Sub-Interfaces
VLAN ID
The VLAN ID.
VLAN Interface CIDR
The VLAN sub-interface IP address.
VRRP Gateway IP
The Default Gateway IP address for this VLAN sub-interface.
Sub-Interface Tag
(optional) A name to identify this VLAN sub-interface.
IP Assignment
Select DHCP or Static, depending on your environment.
This setting cannot be changed after the gateway is created.
Private Network
If the Management interface connection to the Aviatrix Controller is over a private network, set this switch to On.
Leave the setting to Off, if the connection is over the public internet.
Egress CIDR (Optional)
The CIDR range for the egress flow for the Management interface.
The ISO file expires after 24 hours. You cannot download it again and will have to repeat the above steps. You must mount the ISO file to an Edge VM to complete the Edge Gateway registration within 24 hours. See Deploying the Edge Gateway Virtual Machine Instance.
