Creating the Primary and Secondary Edge Spoke Gateway (Aviatrix Edge Platform)
To create a primary and secondary (HA) Edge Spoke Gateway, follow these steps:
Step 1: Gateway Configuration
In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways > Spoke Gateways tab.
Click + Spoke Gateway, then provide the following information.
You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. See Set Up the Aviatrix Edge Platform Account.
Identifies the edge location.
The high availability mode.
On (Active Standby Mode) enables Edge Gateway connection with one active peering and one standby peering. Only the active peering forwards network traffic. The network switches to the standby peering when the primary peering goes down.
Preemptive
Determines the network’s behavior when the primary gateway goes down.
Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
Primary Device
Secondary Device
The gateway size.
Small - 2 vCPU - 4GB
Medium - 4 vCPU - 8GB
Large - 8 vCPU - 16GB
X-Large - 16 vCPU - 32GB
By default, an Edge Spoke Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2. You will need these configuration information to configure the interfaces.
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces. If High Availability mode is selected, then configure both the primary and secondary Edge Gateways.
Configuring the WAN Interface
To configure the WAN interface:
Interface
IP Assignment
Configuring the LAN Interface
To configure the LAN interface:
Interface
IP Assignment
VRRP
VRRP can be configured only if HA Edge Gateway is configured.
VRRP Gateway IP
You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration. Field
VLAN ID
The VLAN ID of the VLAN segment.
VLAN Interface CIDR
The VLAN IP address of the VLAN segment.
The Default Gateway IP address of the VLAN segment.
Sub-Interface Tag
Name to identify the VLAN segment.
When a secondary HA Edge Gateway is configured, the VLAN configurations that are shared between the primary and secondary gateway and are non-editable on the secondary gateway.
To configure the Management interface, click MGMT, then provide the following information.
Field |
Description |
Interface |
IP Assignment |
The MGMT interface defaults to DHCP. This setting cannot be changed. The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge platform. |
Private Network |
Leave this setting to Off. The Edge Gateway on the edge hardware requires public Internet reachability to connect to the Aviatrix Controller and Aviatrix Edge infrastructure in the cloud. |
Egress CIDR (Primary) |
The Egress CIDR is the public IP address which the Management interface uses. If the Public IP is used from Edge Gateway Management interface to establish connectivity to Aviatrix Controller, then configure the Public IP as the CIDR. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway. |
Egress CIDR (Secondary) |
The Egress Public IP for the secondary Edge Gateway’s Management interface when High Availability is configured. |
Step 3: Verify the Edge Gateway Creation
Field |
Description |
Name |
Name for the Edge Gateway. The name must start with a letter and contain only letters, numbers, and dashes (no special characters or spaces) and it can be up to 50 characters long. |
Platform |
The platform account where you want to deploy the Edge Gateway. You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. |
Site |
Identifies the edge location. You can select an existing name or enter a new name for the edge location. |
High Availability |
Preemptive |
Determines the network’s behavior when the primary gateway goes down. Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
Primary Device |
The edge device where you want to deploy the primary Edge Gateway. |
Secondary Device |
Gateway Resource Size |
The gateway size.
Interface Configuration WAN Interface
Field |
Description |
Interface |
This is set to the Edge Gateway’s logical interface. |
IP Assignment |
The default is Static for static IP assignment. DHCP for dynamic IP address assignment is not supported. |
Interface Labels |
Name to identify the WAN interface. |
Interface CIDR |
The CIDR for the WAN interface. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24). |
Default Gateway IP |
The Default Gateway IP address for the WAN interface. For CSP underlay, this is the remote side IP address of the BGP session on CSP VNG or VGW. |
Public IP |
LAN Interface
Field |
Description |
Interface |
IP Assignment |
VRRP |
To enable Virtual Router Redundancy Protocol (VRRP) on the Edge Gateway, set this switch to On. VRRP can be configured only if HA Edge Gateway is configured. |
Interface CIDR |
The native VLAN interface IP address. This interface is where untagged packets are sent. |
VRRP Gateway IP |
The Virtual IP for the VRRP Gateway, when VRRP is enabled. |
The Default Gateway IP address for the native VLAN interface. |
Interface Labels |
Name to identify the native VLAN interface. |
VLAN Interface
If your LAN is segmented into virtual LANs (VLANs), click + VLAN Interface to configure one or more VLAN sub-interfaces.
You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configurations. |
Field |
Description |
VLAN ID |
The VLAN ID of the VLAN segment. VLAN ID must be a number between 2 and 4092. |
VLAN Interface CIDR |
The VLAN IP address of the VLAN segment. |
The Default Gateway IP address of the VLAN segment. |
Sub-Interface Tag |
Name to identify the VLAN segment. |
MGMT Interface
Field |
Description |
Interface |
IP Assignment |
Private Network |
