Aviatrix Secure Edge on On-Premises Deployment Workflow
This document provides instructions for deploying an Aviatrix Edge Gateway on the Aviatrix Edge platform for deployment in datacenters, large campus and office locations for cloud to edge connectivity.
For an overview of Aviatrix Secure Edge, see Aviatrix Secure Edge Overview.
  • Single VLAN connected to the Edge Gateway via a single vNIC.
  • Multiple VLANs connected to the Edge Gateway via a single vNIC (Trunk Port) and sub-interfaces for each VLAN.
  • VRRP on Edge Gateway.
  • LAN-side BGP.
  • Connectivity to single or multiple Transit Gateways from Edge Gateway.
650
Before you can deploy an Aviatrix Edge Gateway on the Aviatrix Edge Platform:
  1. You must perform the prerequisite steps to procure and onboard your edge device. See Prerequisites for Aviatrix Secure Edge Deployment for On-Premises.
  2. You should be familiar with Aviatrix Secure Edge Interfaces and Ports and Protocols. See Edge Gateway WAN, LAN, VLAN, and Management Interface Support.
Creating the Edge Gateway (Aviatrix Platform)
  1. Go to Cloud Fabric > Edge > Edge Gateways tab.
  2. Click + Edge Gateway.
    Provide the following information to create your Edge Gateway.
    The platform where you want to deploy the Edge Gateway.
    You can create and edit platforms in CoPilot by going to Cloud Fabric > Edge > Platforms tab.
    Select the high availability mode.
    • Off creates only the primary Edge Gateway with one active peering.
    • On (Active Standby Mode) enables Edge connection with one active peering and one standby peering. Only the active peering forwards network traffic. The network switches to the standby peering when the primary peering goes down.
    • On (Active Active Mode) enables all Edge connections with active peering to perform load sharing and forward network traffic.
    Preemptive
    Preemptive is turned On only when High Availability is turned On with Active Standby Mode. The Preemptive is set on the Primary gateway.
    • On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
    • Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
    Primary Device
    Name of the edge device where you want to deploy the primary Edge Gateway.
    Secondary Device
    Name of the edge device where you want to deploy the secondary (HA) Edge Gateway.
    The primary and secondary device must have the same hardware configuration.
    Gateway Resource Size
    Select a size for this gateway.
    WAN Interface
    For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is.
    Parameter Description
    IP Assignment
    Interface Tag
    Primary DNS (Optional)
    Secondary DNS (Optional)
    The secondary DNS server IP address, if available.
    (optional) The WAN interface’s egress Public IP address.
    Egress Management IP (Optional)
    The CIDR range for the egress for the MGMT interface.
    LAN Interface
    IP Assignment
    VRRP
    VLAN Interface
    VRRP Gateway IP
    Interface Tag
    VLAN Sub-Interfaces
    VLAN ID
    The VLAN ID.
    VLAN Interface CIDR
    The VLAN sub-interface IP address.
    VRRP Gateway IP
    The Default Gateway IP address for this VLAN sub-interface.
    Sub-Interface Tag
    Name to identify this VLAN sub-interface.
    VLAN configurations are added to the primary and secondary Edge Gateway. If the properties are shared, the fields are disabled on the secondary and non-editable, but the value appears as primary values are selected.
    IP Assignment
    The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge Platform. This setting cannot be changed.
    Private Network
    Leave this setting to Off.
    The Edge Gateway on the edge hardware requires public Internet reachability to connect to the Aviatrix Controller and Aviatrix Secure Edge infrastructure in the cloud.
    Egress CIDR (Optional)
    The CIDR range for the egress for this Management interface.
edge create error message
Verifying Edge Gateway Creation
  1. From the left sidebar, go to Monitor > Notifications > Tasks tab.
  2. In the table, click on the gateway create task to see the progress.
    Depending on the settings you configured, it lists the following stages of the gateway creation:
    1. Creates the primary instance
    2. Updates the primary instance’s interface configurations
    3. Creates the HA instance.
    4. Updates the HA instance’s interface configurations.
Before you attach the Edge Gateway to the Transit Gateway, perform these prerequisite steps.
  1. Ensure Local ASN Number is configured on Edge and Transit Gateway.
  2. If the Edge to Transit Gateway attachment is over public network, you need to update the WAN Public IP on the Edge Gateway.
    2. Locate the Edge Gateway, and click its Edit icon on the right.
    3. In Edit Edge Gateway, scroll to the Interfaces section and click WAN.
    4. In Public IP, click Discover.
      edge discover public ip
    5. Verify the WAN Public IP and click Save.
  • To create a High Performance Encryption mode attachment, make sure the Transit Gateway is created with High Performance Encryption enabled.
  • If you want Jumbo Frame enabled on the Edge Gateway, make sure to enable Jumbo Frame on the Edge Gateway before you attach it to the Transit Gateway.
  2. Locate the Edge Gateway, click the three-dot vertical menu on the right, and select Manage Transit Gateway Attachment.
    edge-attach-edge-to-transit
    Transit Gateway
    Connecting Edge Interfaces
    Attach over Private Network
    • For HPE over private network, setting the number of tunnels count to 0 creates maximum tunnels based on the peering gateway size.
    • For HPE over public network, the number of tunnels count supported range is between 2 and 20.
  3. Click Save.
  1. Navigate to Networking > Connectivity > External Connections (S2C) tab.
  2. Click + External Connection.
    Connect Local Gateway To
    edge external connection
  3. Click Save.
