Aviatrix Secure Edge on Megaport Virtual Edge Deployment Workflow
Aviatrix Secure Edge on Megaport Virtual Edge is available as a Preview Feature in CoPilot version 4.11 with Controller version 7.1.3958.
This document provides instructions for deploying Aviatrix Secure Edge on the Megaport Platform.
For an overview of Aviatrix Secure Edge, see Overview of Aviatrix Secure Edge.
Aviatrix Secure Edge Hybrid Cloud Solution in MegaPort Virtual Edge
The design below shows a high-level hybrid cloud solution with Aviatrix Platform leveraging Megaport fabric.
edge megaport topology
Before you deploy an Aviatrix Edge Gateway on the Megaport Virtual Edge Platform:
  1. You must perform the prerequisite steps to set up a Megaport portal account and a network service provider platform account. For instructions on how to create these accounts, see Prerequisites for Aviatrix Secure Edge Deployment on Megaport Virtual Edge.
  2. You should be familiar with Aviatrix Edge Gateway interfaces and ports and protocols. See Edge Gateway WAN, LAN, VLAN, and Management Interface Support.
Aviatrix Secure Edge Deployment Workflow in Megaport
To deploy Aviatrix Secure Edge, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Aviatrix Secure Edge Deployment on Megaport Virtual Edge). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in Megaport Virtual Edge. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
Creating the ZTP Cloud-Init for the Primary Edge Gateway
The Edge Gateway cloud-init ZTP file is used to provision the Aviatrix Edge Gateway virtual machine and create the Edge Gateway in Megaport Virtual Edge (MVE).
To create the Edge Gateway cloud-init ZTP file, follow these steps.
  1. In CoPilot, go to Cloud Fabric > Edge > Gateways tab.
  2. Click + Gateway, then provide the following information.
    You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Edge > Platforms tab (see Set Up the Network Service Provider Platform Account).
    ZTP File Type
    This is set to cloud-init.
    Deploying multiple Edge Gateways for the same site is supported. A maximum of 16 Edge Gateways is supported.
  3. Configure the WAN, LAN, and Management interfaces.
By default, an Aviatrix Edge Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, LAN, and MGMT), additional two interfaces can be WAN interfaces.
  1. Click + WAN Interface, then provide the following information.
    Parameter Description
    This is set to eth0.
    Adding multiple WAN interfaces is applicable when Edge Gateway is used for BGP underlay to CSP. Add an interface per CSP underlay (such as Direct Connect or Express Route). Aviatrix recommends a maximum of 4 WAN interfaces per Edge Gateway.
    Enables BGP connection on the WAN interface when set On.
    WAN support for BGP underlay to CSP is supported for AWS and Azure.
  2. If BGP is turned On, provide the following information:
    The ASN of the Edge Gateway.
    Password (optional)
    The MD5 authentication key.
  3. To add another WAN interface, click + WAN again and provide the required information.
Configuring the LAN Interface
  1. Click + LAN Interface, then provide the following information.
    This is set to eth1.
  1. Click + MGMT interface. Leave the default settings.
    Leave the Private Network setting to Off. In the Megaport Fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
  2. Click Save.
    If a required field is missing, the respective interface tab is highlighted to indicate there is an error.
    edge create error message nsp
  3. To create the ZTP cloud-init image file, click Save and Download Configuration.
    The cloud-init image file expires after 24 hours. You cannot download it again and will have to repeat the above steps to recreate the file. You must launch an Edge MVE on the Megaport platform and deploy the Edge Gateway within the 24 hours. See Launching the Edge Gateway in Megaport Virtual Edge.
Creating the ZTP Cloud-Init for the Secondary Edge Gateway (Megaport)
  • Before you can create the secondary highly available (HA) Edge Gateway, the primary Edge Gateway must be deployed and its status must be Up.
  • When creating the HA Edge Gateway, the primary Edge Gateway cannot have BGP underlay or BGP over LAN external connections. This does not apply when multiple Edge Gateways are created in the same site without HA configuration.
  • Edge Gateway high availability on the Megaport Platform is supported on the latest Aviatrix Controller release version.
To create a highly available (HA) Edge Gateway, follow these steps.
  1. Go to Cloud Fabric > Edge > Gateways tab.
  2. In the table, locate the primary Edge Gateway for which you want to create the HA gateway and click its Edit icon.
  3. In the Edit Edge Gateway dialog box, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
  4. Configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, MGMT and LAN), additional two interfaces can be WAN interfaces.
    Password (optional)
  1. Click LAN, then provide the following information.
  1. Click + MGMT interface. Leave the default settings and click Save.
    edge equinix ha mgmt interface
  2. To create the ZTP cloud-init image file, click Save and Download Configuration.
Alternative HA Configuration
  1. You can also deploy Edge Gateways in the same site which allows additional Edge Gateways to be deployed in the same site to act in the A/A mode. This is also called horizontal scaling mode.
  2. To deploy additional Gateways, following the same workflow as primary gateway, select the same site as the first gateway and leave the HA option off.
To launch the Aviatrix Edge Gateway in Megaport Virtual Edge (MVE), you must log in to your Megaport Portal to create the MVE and specify the cloud-init file for the Edge Gateway creation and create a Megaport Internet connection for the Management interface for the Edge Gateway authentication with the Aviatrix Controller. For instructions on how to create the MVE and Megaport Internet connection, see Aviatrix with Megaport Virtual Edge in the Megaport documentation.
You will need to create Megaport Internet VXC and attach to the eth2 interface of the Edge Gateway to allow the Edge Gateway access to the Aviatrix Controller.
Once the Aviatrix Edge MVE is created and provisioned, to complete the Edge Gateway authentication with the Aviatrix Controller, you must configure the Edge Gateway Management Egress IP address .
The Management Egress IP address of the Aviatrix Edge Gateway virtual device must be updated from the Aviatrix CoPilot so that the Security Group of the Aviatrix Controller is updated with the correct Egress IP address.
  1. Locate the public IP assigned by Megaport after Internet VXC is attached to the Aviatrix Edge Gateway eth2 interface.
    1. From Megaport Portal, go to Internet VXC attached to the Edge Gateway.
      edge virtual device ip megaport
    2. Click on the VXC Details and note down the public IP address (IPV4).
      edge virtual device ip megaport 2
  2. In Aviatrix CoPilot, navigate to Cloud Fabric > Edge > Gateways tab.
  3. In the table, locate the Edge Gateway and click its Edit icon on the right.
  4. In the Edit Edge Gateway dialog box, scroll to Interface Configuration section, and click MGMT.
  5. Update the Egress CIDR with the Public IP of the Edge Gateway VM from the Megaport VXC Details. Use public IP/32 format, for example 162.43.142.19/32.
    edge mgmt egress ip megaport
  6. Click Save.
Before you attach the Edge Gateway to the Transit Gateway, ensure the Local ASN Number is configured on both gateways.
You can attach an Edge Gateway to multiple Transit Gateways. Each attachment can be configured over the preferred WAN interface, connection over private VXC or public network, high-performance encryption, and Jumbo Frame.
  • To create a High Performance Encryption mode attachment, make sure the Transit Gateway is created with High Performance Encryption enabled.
  • If you want Jumbo Frame enabled on the Edge Gateway, make sure to enable Jumbo Frame on the Edge Gateway before you attach it to the Transit Gateway.
  2. Locate the Edge Gateway, click the three dot vertical menu on the right, and select Manage Transit Gateway Attachment.
    edge-attach-edge-to-transit
  3. Click + Transit Gateway Attachment, then provide the following information.
    Field Description
    Transit Gateway
    Connecting Edge Interfaces
    Multiple WAN interfaces is supported.
  4. In the Advanced section, set the advanced gateway settings that apply.
    Field Description
    Attach over Private Network
    If the Edge WAN connection to the Transit Gateway is over a private network, set this toggle to On. For private VXC, this should be On.
    • For HPE over private network, setting number of tunnels count to 0 creates maximum tunnels based on the peering gateway size.
    • For HPE over public network, the number of tunnels count supported range is between 2 and 20.
  5. To attach the Edge Gateway to another Transit Gateway, click + Transit Gateway Attachment again and provide the required information.
  6. Click Save.
  1. Navigate to Networking > Connectivity > External Connections (S2C) tab.
  2. Click + External Connection, then provide the following information.
    Connect Local Gateway To
  3. Click + Connection and provide the following information.
    edge external connection
  4. Click Save.
