Prerequisites for Aviatrix Secure Edge Deployment on Megaport Virtual Edge
The following are the prerequisites to deploy an Aviatrix Edge Gateway on Megaport Virtual Edge.
1. Obtain a Megaport Portal Account
If you do not already have a Megaport Portal account, refer to Creating an Account in the Megaport documentation.
2. Set Up the Network Service Provider Platform Account
To deploy Aviatrix Edge Gateways on Megaport Virtual Edge, you will need to first set up a Network Service Provider platform account in CoPilot.
3. Provide Network Access
Refer to Aviatrix Edge Gateway Ports and Protocols for the network access requirements for the Edge Gateway to communicate with the Aviatrix Controller, Aviatrix CoPilot, and Aviatrix Transit Gateways.
4. Obtain Edge Gateway Interface Configuration Information
Setting Description
WAN Interface IP/Mask
The WAN IP address.
WAN Default Gateway
LAN Interface IP/Mask
The LAN IP address.
LAN Default Gateway
Management Interface IP/Mask
Not required for DHCP.
Management Default Gateway
The default DHCP.
Management Egress IP
The Management Egress IP address to be allowed in the Controller Security Group.
This is the public IP of the Edge VM assigned by Megaport, which can be obtained once Megaport Internet VXC is connected to the MGMT interface of the Edge Gateway.
Primary DNS Server
Secondary DNS Server
