Aviatrix Secure Edge Use Cases
This document illustrates these common use cases for deploying Aviatrix Secure Edge.
Extend Aviatrix to Edge Locations
This diagram illustrates Aviatrix Edge Gateways deployed at multiple edge locations.
Aviatrix Secure Edge for On-Premises
Cloud Orchestration and Simplified Onboarding
Ease of onboarding
Instantly onboard HW orchestrated via Cloud
Manage and operate the Edge HW and network software via cloud
No IT expertise required to connect and deploy the Edge HW
Drive better cost & FTE efficiencies
Simplified deployment with automation
Deploy Edge network software to multiple devices at scale via Cloud
Single automation stack across cloud and on-prem
Faster deployment and onboarding of connectivity from on-prem to cloud and on-prem to multi-cloud
Increased Performance, Reduced Operational Overhead, and Bottlenecks Removed
IPSec Encrypted line rate throughput from cloud to on-prem via public or private connectivity
Repeatable architecture
Same overlay from Cloud to Edge
Consistent security protocols
Config driven via cloud and consistent secure IPSec state across Edge
E2E visibility – Within Cloud and Cloud to Edge
Multiple Edge Gateways for Multiple Edge Sites
This use case illustrates Edge Gateways with BGP connection to a VIP. The Edge Gateways can be set up at multiple edge sites as shown in the diagram with Site A and Site B.
Multiple Edge Gateways for Single Edge Site
This use case illustrates multiple Edge Gateways on the same edge site for horizontal scaling or multiple Active-Active connections from cloud to edge.
