Aviatrix Secure Edge on On-Premises Deployment Workflow
This document provides instructions for deploying an Aviatrix Edge Gateway on the Aviatrix Edge platform for deployment in datacenters, large campus and office locations for cloud to edge connectivity.
For an overview of Aviatrix Secure Edge, see Aviatrix Secure Edge Overview.
Single VLAN connected to the Edge Gateway via a single vNIC.
Multiple VLANs connected to the Edge Gateway via a single vNIC (Trunk Port) and sub-interfaces for each VLAN.
VRRP on Edge Gateway.
LAN-side BGP.
Connectivity to single or multiple Transit Gateways from Edge Gateway.
Before you can deploy an Aviatrix Edge Gateway on the Aviatrix Edge Platform:
You must perform the prerequisite steps to procure and onboard your edge device. See Prerequisites for Aviatrix Secure Edge Deployment for On-Premises.
You should be familiar with Aviatrix Secure Edge Interfaces and Ports and Protocols. See Edge Gateway WAN, LAN, VLAN, and Management Interface Support.
The diagram below provides a high-level view of the process for deploying Aviatrix Secure Edge in Aviatrix CoPilot.
Creating the Edge Gateway (Aviatrix Platform)
Click + Edge Gateway.
Provide the following information to create your Edge Gateway.
The platform where you want to deploy the Edge Gateway.
You can create and edit platforms in CoPilot by going to Cloud Fabric > Edge > Platforms tab.
Select the high availability mode.
On (Active Standby Mode) enables Edge connection with one active peering and one standby peering. Only the active peering forwards network traffic. The network switches to the standby peering when the primary peering goes down.
On (Active Active Mode) enables all Edge connections with active peering to perform load sharing and forward network traffic.
Preemptive
Preemptive is turned On only when High Availability is turned On with Active Standby Mode. The Preemptive is set on the Primary gateway.
On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
Primary Device
Name of the edge device where you want to deploy the primary Edge Gateway.
Secondary Device
Name of the edge device where you want to deploy the secondary (HA) Edge Gateway.
The primary and secondary device must have the same hardware configuration. Gateway Resource Size
Select a size for this gateway.
WAN Interface
For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is. Parameter Description IP Assignment
Interface Tag
Primary DNS (Optional)
Secondary DNS (Optional)
The secondary DNS server IP address, if available.
(optional) The WAN interface’s egress Public IP address.
Egress Management IP (Optional)
The CIDR range for the egress for the MGMT interface.
To change or update the Edge Gateway WAN connectivity to Transit Gateway, you will need to first detach the Edge-to-Transit gateway attachment, if there is an attachment. LAN Interface
VRRP
VLAN Interface
VRRP Gateway IP
Interface Tag
VLAN Sub-Interfaces
VLAN ID
The VLAN ID.
VLAN Interface CIDR
The VLAN sub-interface IP address.
VRRP Gateway IP
The Default Gateway IP address for this VLAN sub-interface.
Sub-Interface Tag
Name to identify this VLAN sub-interface.
VLAN configurations are added to the primary and secondary Edge Gateway. If the properties are shared, the fields are disabled on the secondary and non-editable, but the value appears as primary values are selected.
The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge Platform. This setting cannot be changed.
Private Network
Leave this setting to Off.
The Edge Gateway on the edge hardware requires public Internet reachability to connect to the Aviatrix Controller and Aviatrix Secure Edge infrastructure in the cloud.
Egress CIDR (Optional)
The CIDR range for the egress for this Management interface.
Verifying Edge Gateway Creation
From the left sidebar, go to Monitor > Notifications > Tasks tab.
In the table, click on the gateway create task to see the progress.
Depending on the settings you configured, it lists the following stages of the gateway creation:
Creates the primary instance
Updates the primary instance’s interface configurations
Creates the HA instance.
Updates the HA instance’s interface configurations.
Before you attach the Edge Gateway to the Transit Gateway, perform these prerequisite steps.
In Edit Edge Gateway, scroll to the Interfaces section and click WAN.
In Public IP, click Discover.
Locate the Edge Gateway, click the three-dot vertical menu on the right, and select Manage Transit Gateway Attachment.
Parameter Description Transit Gateway
Connecting Edge Interfaces
Parameter Description Attach over Private Network
High Performance Encryption
For HPE over private network, setting the number of tunnels count to 0 creates maximum tunnels based on the peering gateway size.
Click + External Connection.
Parameter Description Name
Connect Local Gateway To
