Edge Spoke Gateway Deployment Workflow on Megaport Virtual Edge
| Aviatrix Edge on Megaport Virtual Edge is available as a Preview Feature in CoPilot version 4.11 with Controller version 7.1.3958. |
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on Megaport Virtual Edge.
The design below shows a high-level hybrid cloud solution with Aviatrix Edge leveraging Megaport fabric.
Before you deploy an Aviatrix Edge Gateway on the Megaport Virtual Edge platform, you must perform the prerequisite steps to set up a Megaport Portal account and a Network Service Provider Platform account.
For instructions on how to create these accounts, see Prerequisites for Edge Spoke Gateway Deployment on Megaport Virtual Edge.
Edge Spoke Gateway Deployment Workflow in Megaport
To deploy Aviatrix Edge Spoke Gateway, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Edge Spoke Gateway Deployment on Megaport Virtual Edge). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in Megaport Virtual Edge. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
Creating the ZTP Cloud-Init and Deploying Primary Edge Gateway (Megaport)
The Edge Gateway cloud-init ZTP file is used to provision the Aviatrix Edge Gateway virtual machine and create the Edge Gateway in Megaport Virtual Edge (MVE).
To create the primary Edge Gateway, follow these steps.
Step 1: Gateway Configuration
Click Spoke Gateways, then click +Spoke Gateway and provide the following information.
Identifies the edge location.
See Edge site.
ZTP File Type
This is set to cloud-init.
Click Next to configure the edge gateway interfaces.
Step 2: Interface Configurations
By default, an Edge Spoke Gateway has three interfaces: one WAN interface, one LAN interface, and one Management interface. You can configure multiple WAN interfaces on the Edge Gateway, as needed. You will need these configuration information to configure the interfaces.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, LAN, and MGMT), additional two interfaces can be WAN interfaces.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP). Add an interface per CSP underlay (such as Direct Connect or Express Route).
Password (optional)
The MD5 authentication key.
If BGP is turned On, in Gateway Configuration, enter the Local AS Number of the Edge Gateway.
Configuring the LAN Interface
To configure the Edge Gateway LAN interface, click + LAN Interface, then provide the following information.
Field |
Description |
Interface |
Interface Labels |
Name to identify the LAN interface. |
Interface CIDR |
The CIDR for the LAN interface. DHCP for dynamic IP address assignment is not supported. |
Default Gateway IP |
Click MGMT, then click + MGMT interface.
Leave the Private Network setting to Off. In the Megaport fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
To create the ZTP cloud-init image file, click Done.
Next, log in to Megaport and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
The cloud-init image file expires after 24 hours. You cannot download it again and will have to repeat the above steps to recreate the file. You must launch an Edge MVE on the Megaport platform and deploy the Edge Gateway within the 24 hours.
Creating the ZTP Cloud-Init and Deploying the Secondary Edge Gateway (Megaport)
To create a highly available (HA) Edge Gateway, follow these steps.
In Edit Edge Gateway, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
In Interface Configuration section, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, MGMT and LAN), additional two interfaces can be WAN interfaces.
This is set to eth0.
WAN support for BGP underlay to CSP is supported for AWS and Azure. Interface CIDR
The ASN of the Edge Gateway.
Password (optional)
This is set to eth1.
Leave the Private Network setting to Off. In the Megaport Fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
Attaching Edge Spoke Gateway to Transit Gateway
Click Spoke Gateways.
In Edit Edge Gateway, go to Interface Configuration and click WAN.
In Public IP, click Discover.
To create the attachment:
Locate the Edge Gateway, and click Manage Gateway Attachments icon on the right side of the row.
In Manage Gateway Attachments > Transit Gateway tab, click +Attachment and provide the following information.
Transit Gateway
Local Edge Gateway Interface
Attach Over
High Performance Encryption
Number of Tunnels
To attach the Edge Gateway to another Transit Gateway, click + Attachment again and provide the required information.
Connect Using
Select BGP.
Type
Select LAN.
This is automatically populated if the Edge Gateway is assigned an ASN already. -
In LAN Configuration, provide the following information.
