Edge Spoke Gateway Deployment Workflow on Equinix Network Edge
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on the Equinix Network Edge.
The following diagram shows an example of network connectivity for Aviatrix Edge Spoke Gateway to Transit Gateway in AWS. This topology shows Aviatrix Edge Spoke Gateway connection to an upstream WAN router which is used to terminate CSP underlay private connections.
The topology below shows Aviatrix Edge Spoke Gateway used to terminate CSP underlay private connections (which does not require upstream WAN router).
| Aviatrix Edge Spoke Gateway requires the latest versions of Aviatrix Controller 7.1 and Aviatrix Edge Image 7.1 to support BGP underlay connectivity to CSP. |
Before you can deploy an Aviatrix Edge Spoke Gateway on the Equinix platform, you must perform the prerequisite steps to set up an Equinix account, a Network Service Provider (NSP) platform account, and provide network access.
For instructions to perform these prerequisite steps, see Prerequisites for Edge Spoke Gateway Deployment on Equinix Network Edge.
Edge Spoke Gateway Deployment Workflow in Equinix
To deploy Aviatrix Edge Spoke Gateway, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Edge Spoke Gateway Deployment on Equinix Network Edge). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in Equinix Network Edge. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
Creating the ZTP Cloud-Init for the Primary Edge Spoke Gateway (Equinix)
The Edge Gateway cloud-init ZTP file is used to provision the Edge Gateway virtual machine and create the Edge Gateway in Equinix Fabric.
To create the primary Edge Spoke Gateway, follow these steps.
Step 1: Gateway Configuration
Click Spoke Gateways, then click + Spoke Gateway and provide the following information.
Identifies the edge location.
See Edge site.
ZTP File Type
This is set to cloud-init.
Click Next to configure the edge gateway interfaces.
By default, an Edge Spoke Gateway has three interfaces: one WAN interface, one LAN interface, and one Management interface. You can configure multiple WAN interfaces on the Edge Gateway, as needed. You will need these configuration information to configure the interfaces.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. While up to 8 WAN interfaces is supported, Aviatrix recommends a maximum of 4 WAN interfaces per Edge Gateway.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP). Add an interface per CSP underlay (such as Direct Connect or Express Route).
Password (optional)
The MD5 authentication key.
If BGP is turned On, in Gateway Configuration, enter the Local AS Number of the Edge Gateway.
Configuring the LAN Interface
To configure the Edge Gateway LAN interface, click + LAN Interface, then provide the following information.
Field |
Description |
Interface |
Interface Labels |
Name to identify the LAN interface. |
Interface CIDR |
The CIDR for the LAN interface. DHCP for dynamic IP address assignment is not supported. |
Default Gateway IP |
Click MGMT, then click + MGMT Interface.
Leave the Private Network setting to Off. In the Equinix Platform, the Management interface of the Edge Gateway is assigned the public IP address that is allocated by Equinix.
To create the ZTP cloud-init image file, click Done.
CoPilot downloads the ZTP cloud-init file to your downloads folder.
Next, log in to your Equinix Portal and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on the Equinix platform within that time. You will not be able to download the file again and will have to repeat the steps to recreate a new cloud-init file.
Creating the ZTP Cloud-Init for the Secondary Edge Gateway (Equinix)
In Edit Edge Gateway, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
In Interface Configuration, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
To configure the WAN interface, click + WAN Interface, then provide the following information.
Field |
Description |
Interface |
Add an interface per CSP underlay (such as Direct Connect or Express Route). When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router. |
Interface Labels |
Name to identify the WAN interface. |
BGP |
Enables BGP underlay connection to cloud service provider (CSP) on the WAN interface. Set BGP toggle On to set up BGP connection to cloud routers such as VGW, VNG, and Google cloud router.
Interface Primary CIDR |
The CIDR for the WAN interface. DHCP for dynamic IP address assignment is not supported. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24).
If you need to create a BGP underlay connection to cloud service provider (CSP) with a link-local IP address, you must enter the link-local IP address in the Link-local Underlay CIDR setting of the WAN interface. |
The Default Gateway IP address for the WAN interface. For CSP underlay, this is the remote side IP address of the BGP session on CSP VNG or VGW. If Link-Local Underlay CIDR is configured, the Default Gateway IP should be in the same subnet as the Link-Local Underlay CIDR, otherwise, it should be in the same subnet as the WAN Interface CIDR. |
Public IP |
Field |
Description |
Remote ASN |
The AS Number of the CSP side peering connection such as private VIF on VGW (AWS) and VNG ASN (Azure). |
Local LAN IP |
The IP address of the Edge Gateway. This is the local peering PTP IP for BGP. |
Remote LAN IP |
The IP address of the CSP VNG or VGW peering PTP IP. (GCP is not supported). |
Password (optional) |
The MD5 authentication key. |
To configure the LAN interface, click LAN, then provide the following information.
Field |
Description |
Interface |
Interface Labels |
Interface CIDR |
Attaching Edge Spoke Gateway to Transit Gateway
Click Spoke Gateways.
In Edit Edge Gateway, go to Interface Configuration and click WAN.
In Public IP, click Discover.
To create the attachment:
Locate the Edge Gateway, and click Manage Gateway Attachments icon on the right side of the row.
In Manage Gateway Attachments > Transit Gateway tab, click +Attachment and provide the following information.
Transit Gateway
Local Edge Gateway Interface
Attach Over
High Performance Encryption
Number of Tunnels
To attach the Edge Gateway to another Transit Gateway, click + Attachment again and provide the required information.
Connect Using
Select BGP.
Type
Select LAN.
This is automatically populated if the Edge Gateway is assigned an ASN already. -
In LAN Configuration, provide the following information.
