Configuring Edge Gateway with Transitive Routing
The Transitive Routing feature allows an Edge Gateway to forward routes between multiple Transit Gateways that are connected to it. In Aviatrix Secure Edge, you have the option to enable or disable Transitive Routing for an Edge Gateway; it is disabled by default.
edge-transitive-routing
Configuring Transitive Routing
To configure transitive routing, follow these steps.
  1. Log in to Aviatrix Controller 6.8 or later.
  2. Attach the Edge Gateway to the first Transit Gateway. Follow the steps in Attach Edge Gateway to Transit Gateway.
  3. Repeat and attach the Edge Gateway to the second Transit Gateway.
  4. Navigate to MULTI-CLOUD TRANSIT > Advanced Config > Transitive Routing.
  5. Click the toggle to enable Transitive Routing.
  6. Verify routes on each Aviatrix Transit Gateway.
