Verifying the Edge Gateway Creation
To verify the Edge Gateway is up, wait for 5 minutes after you have deployed the gateway on the Edge platform, then check the Edge Gateway status in Aviatrix CoPilot.
In Aviatrix CoPilot, go to Monitor > Notifications > Tasks tab.
In the table, expand the gateway create task to see the progress.
Depending on the settings that you configured, it lists the following stages of the gateway creation:
Creates the primary gateway
Updates the primary gateway’s interface configurations
Creates the secondary HA gateway.
Updates the secondary HA gateway’s interface configurations.
When all the sub-tasks are complete, the create gateway task status is changed to Completed.
To verify the Edge Gateway status:
Select Spoke Gateways or Transit Gateways.
In the table, locate the Edge Gateway and hover over the Status icon next to the Edge Gateway name.
Verify that the Edge Gateway status is Up.
Click the refresh button to update the registration status.
If the Edge Gateway status is not up, you can troubleshoot edge connectivity using CLI commands on the Edge Gateway console. See Troubleshooting Edge Gateway Connectivity.
