Edge Transit Gateway Deployment Workflow for On-Premises
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Transit Gateways on the Aviatrix Edge platform.
The following diagram shows an example of network connectivity for Edge Transit Gateway to Transit Gateways in the cloud and Edge Spoke Gateways at remote sites.
![eat onpremise topology](_images/eat-onpremise-topology.png)
Before you can deploy an Edge Transit Gateway on the Aviatrix Edge Platform:
You must perform the prerequisite steps to procure and onboard your edge device. See Prerequisites for Edge Transit Gateway Deployment for On-Premises.
Aviatrix Edge Transit Gateway Deployment Workflow
To deploy an Edge Transit Gateway, first you need to procure and onboard your edge devices on the platform of your choice (see Prerequisites for Edge Transit Gateway Deployment for On-Premises).
Next, you deploy the primary and secondary highly available (HA) Edge Transit Gateways on the edge devices. For cloud connectivity, attach the primary Edge Transit Gateway to the Aviatrix Transit Gateway. For LAN-side connectivity, attach the primary Edge Transit Gateway and the Edge Spoke Gateway.
The workflow below guides you through these steps.
Creating the Primary and Secondary Edge Transit Gateway (Aviatrix Edge Platform)
To create a primary and secondary (HA) Edge Transit Gateway, follow these steps.
Step 1: Gateway Configuration
Click + Transit Gateway, then provide the following information.
You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. See Set Up the Aviatrix Edge Platform Account.
Identifies the edge location.
The high availability mode.
Primary Device
Secondary Device
The gateway size.
Small - 2 vCPU - 4GB
Medium - 4 vCPU - 8GB
Large - 8 vCPU - 16GB
X-Large - 16 vCPU - 32GB
By default, an Edge Transit Gateway has two interfaces: one WAN interface on eth0 and one Management interface on eth2. You will need these configuration information to configure the interfaces.
In the Interface Configuration section, configure the WAN and Management interfaces. If High Availability mode is selected, then configure both the primary and secondary Edge Gateways.
Configure the WAN Interface
Edge Transit Gateway on the Aviatrix Edge Platform supports up to 4 WAN interfaces.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP) or other Edge Transit Gateways. A maximum of four WAN interfaces per Edge Gateway is supported.
IP Assignment
Interface Secondary CIDRs
The Local ASN Number of the Edge Gateway.
Password (optional)
The MD5 authentication key.
If BGP is turned On, in Gateway Configuration, enter the Local AS Number of the local Edge Gateway.
In Interface Configuration, click MGMT, then provide the following information.
Interface
IP Assignment
Private Network
Leave this setting to Off.
Egress CIDR (Primary)
Egress CIDR (Secondary)
Step 3: Interface Mapping
Field |
Description |
Interface |
Backup Peering
If the Edge Gateway is deployed in Active-Active high availability mode:
In Backup Peering, select a WAN interface to use to establish the attachment peering between the primary and HA Edge Gateway.
Click Done to create the primary and HA gateways.
Transit Gateway
Local Edge Gateway Interface
Attach Over
Number of Tunnels
Excluded Network CIDRs
If you want to use Jumbo Frames for the attachment peering connection between the Edge Gateways, make sure to enable Jumbo Frames on the Edge Gateways before you create the attachment. |
Spoke Gateway
Remote Edge Gateway Interface
Attach Over
Number of Tunnels
For LAN-side connectivity, you can connect the Edge Gateway to an external device, such as a LAN BGP router.
Field Description Name
Connect Local Gateway To
Field Description Remote LAN IP
