Auto Right-Sizing Maintenance Window
Use Auto Right-Sizing maintenance windows to determine when resizing actions occur. When an operation starts within a maintenance window it will finish even if the operation takes longer than the time remaining in the maintenance window (if the operation has already begun). If an operation has not yet begun, it is moved to the next scheduled run of the maintenance window.
Maintenance Windows Tab
The Maintenance Windows tab shows all scheduled maintenance windows, how many times the maintenance window has been run, and the next time the maintenance window is scheduled to run.
On this sub-tab, you can:
View upcoming schedules and durations for a maintenance window on the Upcoming tab: Click the vertical ellipsis
next to the maintenance window to view upcoming schedules.
View runs related to a maintenance window on the Runs tab: Click the vertical ellipsis
next to the maintenance window to view runs for this maintenance window.
Upcoming Tab
The Upcoming tab shows the scheduled start time of upcoming maintenance windows.
You can click the Scheduled Events link in the maintenance window row to see:
When the maintenance window is scheduled to start
The maintenance window length
The list of gateway instances being resized
Delete scheduled events from the maintenance window
Runs Tab
The Runs tab shows the history of all in-progress and completed maintenance windows, and their associated status.
The status types are:
In Progress: When maintenance begins, the maintenance window schedule moves from the Upcoming tab to the Runs tab and displays as In Progress.
Partial Success: At least one operation within the maintenance window occurred. Operations may be skipped because the maintenance window was not long enough to complete all tasks, or because a gateway instance was already at the correct size.
Skipped: The gateway instance is already at the recommended size, or because the maintenance window was not long enough to complete all tasks.
Error: Errors that occurred during resizing. For example, the gateway instance scheduled to be resized was deleted.
Success: The maintenance window completed all operations successfully.
Stopped: The maintenance window was stopped by a user.
Tasks you can perform on the Runs tab are:
Stopping a maintenance window that is in progress
Viewing the events that occurred during the maintenance window
