Edge Gateway External Connection
Edge Gateway External Connection (S2C) enables you to build secure connectivity between Edge gateways in hybrid and multicloud environments to remote sites such as on-premises, branch offices, and partner locations, by establishing connections to remote routers and firewalls that terminate VPN connection.
