Deploy an Edge Spoke Gateway on Aviatrix Edge Platform
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on the Aviatrix Edge Platform.
  • Single VLAN connected to the Edge Gateway via a single vNIC.
  • Multiple VLANs connected to the Edge Gateway via a single vNIC (Trunk Port) and sub-interfaces for each VLAN.
  • VRRP on Edge Gateway.
  • LAN-side BGP.
  • Connectivity to single or multiple Transit Gateways from Edge Gateway.
650
Before you deploy an Edge Spoke Gateway on the Aviatrix Edge Platform, ensure the prerequisite steps are complete.
Create the Primary and Secondary Edge Spoke Gateway (Aviatrix Edge Platform)
Follow the steps below to create and deploy a primary and secondary highly available (HA) Edge Transit Gateways on the Aviatrix Edge platform.
This diagram provides a high-level view of the process for deploying Edge Spoke Gateway using Aviatrix CoPilot.
edge aviatrix workflow
Step 1: Gateway Configuration
  1. In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways > Spoke Gateways tab.
  2. Click + Spoke Gateway, then provide the following information.
    A name for the Edge Gateway.
    The name must begin with a letter, may include only letters, numbers, and dashes (excluding special characters or spaces), and must not exceed 50 characters in length.
    The platform account where you want to deploy the Edge gateway.
    Identifies the edge location.
    The high availability mode.
    • Off creates only the primary Edge Gateway with one active peering.
    • On (Active Standby Mode) enables Edge gateway connection with one active peering and one standby peering. Only the active peering forwards network traffic. The network switches to the standby peering when the primary peering goes down.
    • On (Active Active Mode) enables Edge Gateway connections with all active peerings to perform load sharing and forward network traffic.
    Preemptive
    Determines the network’s behavior when the primary gateway goes down.
    Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
    • On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
    • Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
    Primary Device
    Secondary Device
    The primary and secondary devices must have the same hardware configuration.
    Gateway Resource Size
    The gateway size.
    • Small - 2 vCPU - 4GB
    • Medium - 4 vCPU - 8GB
    • Large - 8 vCPU - 16GB
    • X-Large - 16 vCPU - 32GB
  3. Click Next to configure the gateway interfaces.
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces. By default, an Edge Spoke Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2. You will need these IP addresses to configure the interfaces.
If High Availability mode is selected, then configure both the primary and secondary Edge gateway interfaces.
Configure the WAN Interface
To configure the WAN interface:
  1. In Interface Configuration, click WAN, then provide the following information.
    Interface
    IP Assignment
Configure the LAN Interface
To configure the LAN interface:
  1. Click LAN, then provide the following information.
    Interface
    IP Assignment
    VRRP
    VRRP can be configured only if HA Edge Gateway is configured.
    VRRP Gateway IP
  2. If your LAN is segmented into virtual LANs (VLANs), click + VLAN Interface to add one or more VLAN sub-interfaces, then provide the following information for each VLAN sub-interface.
    You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration.
    VLAN ID
    The VLAN ID of the VLAN segment.
    VLAN Interface CIDR
    The VLAN IP address of the VLAN segment.
    The Default Gateway IP address of the VLAN segment.
    Sub-Interface Tag
    Name to identify the VLAN segment.
    When a secondary HA Edge Gateway is configured, the VLAN configurations that are shared between the primary and secondary gateway and are non-editable on the secondary gateway.
Configure the MGMT Interface
To configure the Management interface, click MGMT, then provide the following information.
Interface
IP Assignment
Private Network
Leave this setting to Off.
Egress CIDR (Primary)
Egress CIDR (Secondary)
Step 3: Interface Mapping
The table shows a mapping of the Edge Gateway’s logical interface names to the Edge Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. When performing diagnostic or troubleshooting on the Aviatrix Platform, you can refer to this mapping for the interface name.
Interface
Primary Gateway Ethernet Interface
The primary Edge Gateway’s Linux interface name.
Secondary Gateway Ethernet Interface
The secondary (HA) Edge Gateway’s Linux interface name.
The secondary gateway interface mappings are shown only when high availability is configured for the primary Edge Gateway.
Next Steps
