Prerequisites for Edge Spoke Gateway Deployment on Aviatrix Edge Platform
The following are the prerequisites to deploy an Aviatrix Edge Spoke Gateway on the Aviatrix Edge Platform.
1. Procure and Onboard the Edge Device
Before you can deploy an Aviatrix Edge Spoke Gateway, you must procure and onboard your edge device onto the Aviatrix Edge Platform. For more information, see Installing Edge OS and Onboaring Dell Hardware.
2. Obtain Edge Gateway Interface IP Addresses
The Edge Spoke Gateway on the Aviatrix Edge Platform supports one WAN, one LAN, and one Management interface.
You will need to provide the following information during Edge Gateway creation for your primary and secondary HA Edge Gateways.
WAN Interface
LAN Interface
VRRP Gateway IP
Not required if not using Virtual Router Redundancy Protocol (VRRP).
VLAN ID
The VLAN ID of the VLAN segment.
VLAN Interface CIDR
The VLAN IP address of the VLAN segment.
The Default Gateway IP address of the VLAN segment.
MGMT Interface Description
IP Assignment
Private Network
Leave this setting to Off.
Egress CIDR (Primary)
Egress CIDR (Secondary)
3. Provide Network Access
Aviatrix Edge Spoke Gateway requires outbound access to communicate with the Aviatrix Platform. You must allow access on the specified ports on your firewall.
For all Edge gateway outbound access requirements, see Aviatrix Products: Required Access for External Sites on the Aviatrix Customer Support website.
