Create Edge Transit Gateway Attachments
An Edge Transit Gateway can be attached to multiple Aviatrix gateways for hybrid, multicloud, and LAN connectivity.
For encrypted connectivity across network service providers (NSPs), such as Equinix and Megaport, and Datacenter fabric, create an Edge Transit Gateway to Edge Transit Gateway attachment.
For encrypted connectivity to cloud, create an Edge Transit Gateway to a Transit Gateway attachment.
For encrypted connectivity to remote site or on-premises, create an Edge Transit Gateway to an Edge Spoke Gateway attachment.
Attach an Edge Transit Gateway to Edge Transit Gateway
If you want to use Jumbo Frames for the attachment peering connection between the Edge Gateways, make sure to enable Jumbo Frames on the Edge Gateways before you create the attachment. |
To attach an Edge Transit Gateway to an Edge Transit Gateway:
Locate the Edge Transit Gateway to which you want to attach an Edge Transit Gateway, then click the Manage Gateway Attachments icon
on the right side of the row.
Transit Gateway
The remote Edge Transit Gateway to attach.
Local Edge Gateway Interface
The WAN interface of the local Edge Transit Gateway to use for the attachment.
Remote Edge Gateway Interface
The WAN interface of the remote Edge Transit Gateway to use for the attachment.
In the Advanced section, enter or select the following:
Attach Over
The connection between the Edge gateways. It can be over a Private Network or the Public Network.
On the Aviatrix Edge Platform (AEP), Edge Transit Gateway to Edge Transit Gateway peering for high performance encryption is supported over private and public networks.
On the Equinix and Megaport platforms, Edge Transit to Edge Transit peering for high performance encryption is supported over private network only .
Jumbo Frame improves performance for the connection between the Edge gateways.
Jumbo Frame is applicable when the attachment is over a Private network.
To use Jumbo Frames for the connection , set Jumbo Frame toggle to On.
ActiveMesh
ActiveMesh enables full mesh peering between the local and remote Edge gateways.
For full mesh peering, turn ActiveMesh toggle On.
Number of HPE Tunnels
The number of High Performance Encryption (HPE) tunnels to create for the attachment peering. By default, a single tunnel is created.
This option is available only for connection over a Private network.
Excluded Network CIDRs
To attach the Edge Transit Gateway to another Edge Transit Gateway, click + Attachment again and provide the required information.
You can attach an Edge Transit Gateway to multiple Edge Transit Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
Attach an Edge Transit Gateway to Transit Gateway
Locate the Edge Transit Gateway to which you want to attach the Transit Gateway, then click the Manage Gateway Attachments icon
Transit Gateway
The Transit Gateway in cloud to attach.
Attach Over
Attach an Edge Transit Gateway to Edge Spoke Gateway
Locate the Edge Transit Gateway to which you want to attach the Edge Spoke Gateway, then click the Manage Gateway Attachments icon
Spoke Gateway
The remote Edge Spoke Gateway to attach.
The WAN interface of the remote Edge Spoke Gateway to use for the attachment.
Attach Over
ActiveMesh
