Edge Spoke Gateway Deployment Workflow for On-Premises
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on Aviatrix Edge Platform.
Single VLAN connected to the Edge Gateway via a single vNIC.
Multiple VLANs connected to the Edge Gateway via a single vNIC (Trunk Port) and sub-interfaces for each VLAN.
VRRP on Edge Gateway.
LAN-side BGP.
Connectivity to single or multiple Transit Gateways from Edge Gateway.
Before you can deploy an Edge Spoke Gateway on the Aviatrix Edge Platform:
You must perform the prerequisite steps to procure and onboard your edge device. See Planning and Deployment of Edge Spoke Gateway.
You should be familiar with the Edge Spoke Gateway interfaces. See Edge Spoke Gateway Interfaces.
Edge Spoke Gateway Deployment Workflow in Aviatrix Edge Platform
To deploy an Edge Spoke Gateway, first you need to procure and onboard your edge devices on the platform of your choice (see Planning and Deployment of Edge Spoke Gateway).
Next, you deploy the primary and secondary highly available (HA) Edge Spoke Gateways on the edge devices. For cloud connectivity, attach the primary Edge Spoke Gateway to the Transit Gateway. For LAN-side connectivity, attach the primary Edge Spoke Gateway and the LAN-side router.
The diagram below provides a high-level view of the process for deploying Edge Spoke Gateway using Aviatrix CoPilot.
The workflow below guides you through these steps.
Creating the Primary and Secondary Edge Spoke Gateway (Aviatrix Edge Platform)
To create a primary and secondary (HA) Edge Spoke Gateway, follow these steps:
Step 1: Gateway Configuration
In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways > Spoke Gateways tab.
Click + Spoke Gateway, then provide the following information.
Identifies the edge location.
The high availability mode.
On (Active Standby Mode) enables Edge Gateway connection with one active peering and one standby peering. Only the active peering forwards network traffic. The network switches to the standby peering when the primary peering goes down.
Preemptive
Determines the network’s behavior when the primary gateway goes down.
Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
Primary Device
Secondary Device
The gateway size.
Small - 2 vCPU - 4GB
Medium - 4 vCPU - 8GB
Large - 8 vCPU - 16GB
X-Large - 16 vCPU - 32GB
By default, an Edge Spoke Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2. You will need these IP addresses to configure the interfaces.
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces. If High Availability mode is selected, then configure both the primary and secondary Edge Gateways.
Configuring the WAN Interface
To configure the WAN interface:
Interface
IP Assignment
Configuring the LAN Interface
To configure the LAN interface:
Interface
IP Assignment
VRRP
VRRP can be configured only if HA Edge Gateway is configured.
VRRP Gateway IP
You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration. Field
VLAN ID
The VLAN ID of the VLAN segment.
VLAN Interface CIDR
The VLAN IP address of the VLAN segment.
The Default Gateway IP address of the VLAN segment.
Sub-Interface Tag
Name to identify the VLAN segment.
When a secondary HA Edge Gateway is configured, the VLAN configurations that are shared between the primary and secondary gateway and are non-editable on the secondary gateway.
To configure the Management interface, click MGMT, then provide the following information.
Field |
Description |
Interface |
IP Assignment |
The MGMT interface defaults to DHCP. This setting cannot be changed. The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge platform. |
Private Network |
Leave this setting to Off. The Edge Gateway on the edge hardware requires public Internet reachability to connect to the Aviatrix Controller and Aviatrix Edge infrastructure in the cloud. |
Egress CIDR (Primary) |
The Egress CIDR is the public IP address which the Management interface uses. If the Public IP is used from Edge Gateway Management interface to establish connectivity to Aviatrix Controller, then configure the Public IP as the CIDR. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway. |
Egress CIDR (Secondary) |
The Egress Public IP for the secondary Edge Gateway’s Management interface when High Availability is configured. |
Attaching Edge Spoke Gateway to Transit Gateway
Click Spoke Gateways.
In Edit Edge Gateway, go to Interface Configuration and click WAN.
In Public IP, click Discover.
To create the attachment:
Locate the Edge Gateway, and click Manage Gateway Attachments icon on the right side of the row.
In Manage Gateway Attachments > Transit Gateway tab, click +Attachment and provide the following information.
Transit Gateway
Local Edge Gateway Interface
Attach Over
High Performance Encryption
Number of Tunnels
To attach the Edge Gateway to another Transit Gateway, click + Attachment again and provide the required information.
Connect Using
Select BGP.
Type
Select LAN.
This is automatically populated if the Edge Gateway is assigned an ASN already. -
In LAN Configuration, provide the following information.
