This document provides instructions to deploy a primary Edge Transit Gateway on Megaport Virtual Edge (MVE). For an overview of Aviatrix Edge, see About Aviatrix Hybrid Cloud Edge.
Before you deploy an Edge Transit Gateway on the Megaport platform, ensure the prerequisite steps are complete.
Deploy the Primary Edge Transit Gateway (Megaport)
To create and deploy the primary Edge Transit Gateway in Megaport Virtual Edge (MVE), first you need to generate the cloud-init file in CoPilot, then deploy the Edge gateway in MVE using the cloud-init file:
  1. Create the Primary Edge Transit Gateway cloud-init ZTP file.
  2. Deploy the Edge Transit Gateway in MVE using the cloud-init ZTP file.
  3. Verify the Edge Transit Gateway creation.
Next Steps
