The design below shows a high-level hybrid cloud solution with Aviatrix Edge leveraging Megaport fabric.
Before you deploy an Edge Spoke Gateway on the Megaport platform, ensure the prerequisite steps are complete.Deploy the Primary Edge Spoke Gateway (Megaport)
To create and deploy the primary Edge Spoke Gateway in Megaport Virtual Edge (MVE), perform these steps.- Create the Primary Edge Spoke Gateway ZTP Cloud-Init File (Megaport).
- Deploy the Edge Spoke Gateway in MVE using the cloud-init ZTP file.
- Verify the Edge Spoke Gateway creation.
Next Steps
- For high availability (HA) and redundancy, you can create and deploy HA Edge Spoke Gateway. See Deploy a HA Edge Spoke Gateway (Megaport).
- For hybrid, multicloud, or LAN-side connectivity, you can attach the Edge Spoke Gateway to multiple Aviatrix gateways. See Edge Gateway Attachments.
- For remote site connectivity, you can connect the Edge Spoke Gateway to remote devices. See Edge Gateway External Connection.
