The edge devices supported on the Aviatrix Edge Platform requires egress over the public internet to communicate with the Aviatrix Platform. If internet traffic is routed through a proxy server, you can configure a proxy profile and associate the profile with the edge device.
Creating a Proxy Profile
To configure a proxy profile, follow these steps.
  1. In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Devices tab.
  2. Click Proxy Profiles.
  3. In Proxy Profiles, click + Proxy Profile, then provide the following information.
FieldDescription
NameA name for the proxy profile.
Transparent ModeIf you use a Transparent proxy server, set Transparent Mode toggle to On. A Proxy CA Certificate is required when Transparent Mode is On.
Proxy Server IPThe IP address of the Proxy server.
PortThe port number used for the Proxy server.
Proxy CA CertificateThe certificate authority (CA) certificate to use on the edge device. The Proxy CA certificate must be in Privacy Enhanced Mail (PEM) file format.
  1. Click Save.
You can now use the proxy profile to configure the Management interface of the edge device when you onboard the device.
Modifying or Deleting a Proxy Profile
If a proxy profile is associated with an edge device, modifying the proxy file may result in communication disruptions with the Aviatrix platform.
To modify a proxy profile:
  3. In the table, locate the proxy profile you want to edit and click the Edit icon on the right.
  4. Make any changes needed.
  5. Click Save.
To delete a proxy profile:
  3. In the table, locate the proxy profile you want to delete and click the Delete icon on the right.
The Delete icon is disabled if a proxy profile is associated with any edge device. You must first remove the proxy profile association for the edge devices.
  1. To confirm the deletion, click Delete.
Removing a Proxy Profile Association for an Edge Device
To remove a proxy profile association for an edge device:
  2. In the table, locate the edge device and click the Edit icon on the right.
  3. Delete the proxy profile associated with the MGMT interface.
  4. Click Save.
