An Edge Transit Gateway can be attached to multiple Aviatrix gateways for hybrid, multicloud, and LAN connectivity.
Attach an Edge Transit Gateway to Edge Transit Gateway
If you want to use Jumbo Frames for the attachment peering connection between the Edge Gateways, make sure to enable Jumbo Frames on the Edge Gateways before you create the attachment.
To attach an Edge Transit Gateway to an Edge Transit Gateway:
  1. In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways > Transit Gateways tab.
  2. Locate the Edge Transit Gateway to which you want to attach an Edge Transit Gateway, then click the Manage Gateway Attachments icon manage attachment link icon on the right side of the row.
  3. In Manage Gateway Attachments > Transit Gateway tab, click + Attachment and provide the following information.
    FieldDescription
    Transit GatewayThe remote Edge Transit Gateway to attach.
    Local Edge Gateway InterfaceThe WAN interface of the local Edge Transit Gateway to use for the attachment.
    Remote Edge Gateway InterfaceThe WAN interface of the remote Edge Transit Gateway to use for the attachment.
    In the Advanced section, enter or select the following:
    FieldDescription
    Attach OverThe connection between the Edge gateways. It can be over a Private Network or the Public Network. On the Aviatrix Edge Platform (AEP), Edge Transit Gateway to Edge Transit Gateway peering for high performance encryption is supported over private and public networks. On the Equinix and Megaport platforms, Edge Transit to Edge Transit peering for high performance encryption is supported over private network only. Regular encryption is supported over both private and public networks for all environments.
    Jumbo FrameJumbo Frame improves performance for the connection between the Edge gateways. Jumbo Frame is applicable when the attachment is over a Private network. To use Jumbo Frames for the connection, set Jumbo Frame toggle to On.
    ActiveMeshActiveMesh enables full mesh peering between the local and remote Edge gateways. For full mesh peering, set ActiveMesh toggle On.
    Number of HPE TunnelsThe number of High Performance Encryption (HPE) tunnels to create for the attachment peering. Single creates a single tunnel. Maximum creates the maximum tunnels based on the gateway sizes and the number of interface IPs on the peering gateway. This option is available only for connection over a Private network. Custom allows you to specify the number of tunnels to create.
    Excluded Network CIDRsIf you want to exclude CIDRs from the local Edge Gateway from being propagated to the remote Edge Gateway, set Excluded Network CIDRs toggle to On. In Excluded Network CIDRs field, enter the CIDRs to be excluded.
  4. To attach the Edge Transit Gateway to another Edge Transit Gateway, click + Attachment again and provide the required information. You can attach an Edge Transit Gateway to multiple Edge Transit Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
  5. Click Save.
Attach an Edge Transit Gateway to Transit Gateway
To create a High Performance Encryption (HPE) attachment, make sure the Transit Gateway in the cloud is created with HPE enabled.
If you want to use Jumbo Frames for the attachment, make sure to enable Jumbo Frames on the Edge Transit Gateway and the Transit Gateway in the cloud before you create the attachment.
  2. Locate the Edge Transit Gateway to which you want to attach the Transit Gateway, then click the Manage Gateway Attachments icon manage attachment link icon on the right side of the row.
    FieldDescription
    Transit GatewayThe Transit Gateway in cloud to attach.
  4. To attach the Edge Transit Gateway to another Transit Gateway, click + Attachment again and provide the required information. You can attach an Edge Transit Gateway to multiple Transit Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
  5. Click Save.
Attach an Edge Transit Gateway to Edge Spoke Gateway
  2. Locate the Edge Transit Gateway to which you want to attach the Edge Spoke Gateway, then click the Manage Gateway Attachments icon manage attachment link icon on the right side of the row.
  3. In Manage Gateway Attachments > Spoke Gateway tab, click + Attachment and provide the following information.
    FieldDescription
    Spoke GatewayThe remote Edge Spoke Gateway to attach.
    Remote Edge Gateway InterfaceThe WAN interface of the remote Edge Spoke Gateway to use for the attachment.
    Attach OverThe connection between the Edge gateways. It can be over a Private Network or the Public Network. On the Aviatrix Edge Platform (AEP), Edge Transit Gateway to Edge Spoke Gateway peering for high performance encryption over private and public networks is supported. On the Equinix and Megaport platforms, Edge Transit Gateway to Edge Spoke Gateway peering for high performance encryption is supported over private networks only. Regular encryption is supported over both private and public networks for all environments.
  4. To attach the Edge Transit Gateway to another Edge Spoke Gateway, click + Attachment again and provide the required information. You can attach an Edge Transit Gateway to multiple Spoke Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
  5. Click Save.
