This document provides instructions to deploy a primary Edge Spoke Gateway on Equinix Network Edge. For an overview of Aviatrix Edge, see About Aviatrix Hybrid Cloud Edge.
The following diagram shows an example of network connectivity for Aviatrix Edge Spoke Gateway to Transit Gateway in AWS. This topology shows Aviatrix Edge Spoke Gateway connection to an upstream WAN router which is used to terminate CSP underlay private connections. Edge Equinix Topology 1 The topology below shows Aviatrix Edge Spoke Gateway used to terminate CSP underlay private connections (which does not require upstream WAN router). Edge Equinix Topology 2
Aviatrix Edge Spoke Gateway requires the latest versions of Aviatrix Controller 7.1 and Aviatrix Edge Image 7.1 or higher to support BGP underlay connectivity to CSP.
Before you deploy an Aviatrix Edge Spoke Gateway on the Equinix platform, ensure the prerequisite steps are complete.
Deploy the Primary Edge Spoke Gateway (Equinix)
To deploy an Edge Spoke Gateway, first you need to generate the cloud-init file in CoPilot, then deploy the Edge gateway in Equinix using the cloud-init file:
  1. Create the Primary Edge Spoke Gateway cloud-init ZTP file.
  2. Deploy the Edge Spoke Gateway in Equinix using the cloud-init ZTP file.
  3. Verify the Edge Spoke Gateway creation.
Next Steps
