BGP Configuration
Go to Advanced Config → BGP
BGP Transit GW List
If you setup a Transit Network, Transit GWs will be listed under Settings > Advanced Config > BGP.
Select one Transit GW to view details.
  • Advertised Networks represents the list of Spoke GW CIDR list.
  • Learned routes represents the list of on-prem network propagated by VGW.
  • Local AS Num is the Transit GW AS number you specified when connecting the VGW to the external device.
BGP Dampening
The BGP dampening feature can be used to suppress flapping routes. It is disabled by default. You cannot configure dampening parameters.
