Aviatrix Secure Edge on Equinix Network Edge Deployment Workflow
This document provides instructions for deploying Aviatrix Secure Edge on Equinix Network Edge.
For an overview of Aviatrix Secure Edge, see Aviatrix Secure Edge Overview.
The following diagram shows an example of network connectivity for Aviatrix Secure Edge Gateway to Transit Gateway in AWS. This topology shows Aviatrix Secure Edge connection to an upstream WAN router which is used to terminate CSP underlay private connections.
The topology below shows Aviatrix Secure Edge used to terminate CSP underlay private connections (which does not require upstream WAN router).
Aviatrix Secure Edge requires the latest version of Aviatrix Controller 7.1 and Aviatrix Secure Edge Image 7.1 to support BGP underlay connectivity to CSP. |
Before you deploy an Aviatrix Edge Gateway on the Equinix Platform:
You must perform the prerequisite steps to set up an Equinix account, Platform account, and provide network access. See Prerequisites for Aviatrix Secure Edge Deployment for Equinix Network Edge.
You should be familiar with Aviatrix Edge Gateway Interfaces and Ports and Protocols. See Edge Gateway WAN, LAN, VLAN, and Management Interface Support.
This workflow provides steps to create a primary and secondary Edge Gateway in Equinix Network Edge, attach the Edge Gateways to a Transit Gateway, and connect the Edge Gateways to an external device.
Creating the ZTP Cloud-Init for the Primary Edge Gateway
The Edge Gateway cloud-init ZTP file is used to provision the Aviatrix Edge Gateway virtual machine and create the Edge Gateway in Equinix Fabric.
To create the Edge Gateway cloud-init ZTP file, follow these steps.
In CoPilot, go to Cloud Fabric > Edge > Edge Gateways tab.
Click + Edge Gateway.
Parameter Description Name
The platform where you want to deploy the Edge Gateway.
You can create and edit platforms in CoPilot by going to Cloud Fabric > Edge > Platforms tab.
ZTP File Type
This is set to cloud-init.
Deploying multiple Edge Gateways for the same site is supported. A maximum of 16 Edge Gateways is supported.
WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. While up to 8 WAN interfaces is supported, Aviatrix recommends a maximum of 4 WAN interfaces per Edge Gateway.
This is set to eth0.
Adding multiple WAN interfaces is applicable when Edge Gateway is used for BGP underlay to CSP. Add an interface per CSP underlay (such as Direct Connect or Express Route). Aviatrix recommends a maximum of 4 WAN interfaces per Edge Gateway. When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router.
Interface Tag
To enable BGP connection on the Edge Gateway, set this switch to On.
WAN support for BGP underlay to CSP is currently only supported for AWS and Azure. Interface CIDR
The ASN of the Edge Gateway.
Local Tunnel IP
Remote Tunnel IP
Password (optional)
The MD5 authentication key.
To change or update the Edge Gateway WAN connectivity to Transit Gateway, you will need to first detach the Edge-to-Transit gateway attachment, if there is an attachment. LAN Interface
Click + LAN Interface, then provide the following information.
This is set to eth1.
Interface Tag
Leave the Private Network setting to Off. In the Equinix Platform, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Equinix.
Below is an example WAN, LAN, and MGMT configuration for Edge Gateway with BGP underlay to CSPs.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM on Equinix platform within that time, as you cannot download it again and will have to recreate the cloud-init file.
Creating the ZTP Cloud-Init for the Secondary Edge Gateway (Equinix Platform)
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
WAN Interface
Interface Tag
The WAN interface’s egress Public IP address.
Local Tunnel IP
Remote Tunnel IP
Password (optional)
Interface Tag
For BGP over LAN, set this switch to turn BGP mode On.
Launching the Edge Gateway in Equinix Network Edge
To launch the Aviatrix Edge Gateway in Equinix Network Edge, see Create an Aviatrix Edge in the Equinix documentation. Demo video: Step-by-Step Guide to Deploy Aviatrix Secure Edge on Equinix Network Edge on Vimeo.
You will need to create an Access Control List Template to allow CoPilot access to the Aviatrix Edge virtual device. |
Once the Aviatrix Edge virtual device is created and provisioned, an email is sent to the notification email you provided informing that the Aviatrix Edge virtual device is provisioned.
Creating the Access Control List Template for CoPilot
The Access Control List Template defines the inbound rules for the Aviatrix Edge Gateway virtual device to allow specific inbound traffic. Aviatrix Controller and CoPilot needs to communicate with the Aviatrix Edge Gateway. Inbound traffic from the Controller and CoPilot must be allowed on the Edge Gateway virtual device.
Controller’s IP address will be automatically allowed based on the cloud-init. |
To define the inbound rules for CoPilot, in the CreateNew Access Control List Management Template page, provide the following information.
In the Basic Details section, enter a name for the Access Control List template and a description.
In the Inbound Rules section, enter the following information:
For IP Address Subnet, enter the CoPilot public or private IP address.
For Protocol, select IP from the drop-down.
For Description (Optional), enter a description for this rule.
Click Add Rule.
To create the Access Control List template, click Create Template.
The Management Egress IP address of the Aviatrix Edge Gateway virtual device must be updated from the Aviatrix CoPilot so that the Security Group is updated with the correct Egress IP address.
Locate the public IP assigned by Equinix during Aviatrix Edge virtual device creation.
From Equinix Fabric Portal, go to Network Edge > Virtual Device Inventory > Details and locate the Public IP address of the device.
In Aviatrix CoPilot, navigate to Cloud Fabric > Edge > Edge Gateways tab.
Update the Egress CIDR with the Public IP from the Equinix Fabric Portal.
Before you attach the Edge Gateway to the Transit Gateway, ensure the Local ASN Number is configured on both gateways.
Connecting Edge Interfaces
Multiple WAN interfaces is supported.
High Performance Encryption
For HPE over private network, setting number of tunnels count to 0 creates maximum tunnels based on the peering gateway size.
Click + External Connection.
Connect Local Gateway To
