Edge Gateway Requirements
The following sections provide the Edge Gateway virtual machine and network port access requirements for Edge Gateway deployment.
Virtual Machine CPU and Memory Configurations
This table provides the CPU and memory specifications of the virtual machine instance supported for the Aviatrix Edge Gateway deployment.
Deployment Type | Hardware Profile | Storage Requirements | Note |
Small |
2 vCPU - 4GB |
64 GB |
<1Gbps Throughput |
Medium |
4 vCPU - 8GB |
64 GB |
<5Gbps throughput |
Large |
8 vCPU - 16GB |
64 GB |
~10Gbps throughput |
X-Large |
16 vCPU - 32GB |
64 GB |
We recommend that you do not change the Edge VM resource allocation after deploying it. Aviatrix support may not be able to assist with any issue that occurs on a system with customized resource allocation. |
Over subscription of host resources can lead to a reduction of performance and your instance could become unstable. We recommend that you follow the guidelines and the best practices for your host hypervisor.
Aviatrix Edge Gateway Ports and Protocols
The Aviatrix Edge Gateway requires outbound access to communicate with the Aviatrix Controller. You must allow access on these ports on your firewall.
Additional required outbound ports are described in the table below. |
Source | Destination | Port | Purpose |
WAN eth0 |
Aviatrix Transit Gateway eth0 private or public IP address. If multiple WAN interfaces are configured, this access must be allowed for all WAN links. |
UDP 500 |
IPsec |
WAN eth0 |
UDP 4500 |
IPsec |
Mgmt eth2 |
DNS server |
UDP 53 |
DNS lookup |
Mgmt eth2 |
Aviatrix Controller FQDN or private or public IP address. |
TCP 443 |
Edge to Controller |
Mgmt eth2 |
Aviatrix CoPilot FQDN or private or public IP address. |
UDP 5000 |
Syslog |
Mgmt eth2 |
UDP 31283 |
Netflow |
