Prerequisites for Aviatrix Secure Edge Deployment for On-Premises
The following are the prerequisites to deploy an Aviatrix Edge Gateway for on-premise on the Aviatrix Edge platform.
1. Procure the Edge Hardware
If you do not already have your edge hardware, you need to evaluate the hardware that you require for your edge computing and procure the hardware. Contact your Aviatrix account manager for the hardware you may require.
For a list of Aviatrix supported hardware appliances, see Aviatrix Secure Edge - Hardware Specifications.
2. Obtain the Hardware Serial Number
To register edge hardware with the Aviatrix Edge platform, you will be required to provide the hardware serial number. Obtain the serial numbers for your edge hardware.
3. Onboard the Aviatrix Edge Platform Account
You need to set up an Aviatrix Edge Platform Account, before you can onboard and register the edge hardware appliance with the Aviatrix Controller.
4. Onboard the Edge Hardware
You must onboard and register the edge hardware appliance with the Aviatrix Controller, before you can deploy an Edge Gateway on the edge hardware.
To onboard edge hardware, see Onboarding Edge Hardware for the Aviatrix Edge Platform.
5. Obtain Edge Gateway Interface Configurations
Setting | Description |
WAN Interface IP/Mask |
The WAN IP address. |
WAN Default Gateway |
LAN Interface IP/Mask |
The LAN IP address. |
LAN Default Gateway |
The Default Gateway IP address for the LAN interface. |
Management Interface IP/Mask |
The Management IP address. Not required for DHCP. |
Management Default Gateway |
The Default Gateway IP address for the Management interface. Not required for DHCP. |
Management Egress IP |
The Management Egress IP address to be allowed in the Controller Security Group. |
Primary DNS Server |
The Primary DNS server IP address. Not required for DHCP. |
Secondary DNS Server |
The Secondary DNS server IP address. Not required for DHCP. |
VRRP |
The VRRP IP address. Not required if not using VRRP. VRRP can be configured only if HA gateway is configured. |
VLAN ID |
The VLAN ID for each VLAN segment. |
VLAN IP |
The VLAN IP address for each VLAN segment. |
VLAN Default Gateway |
The Default Gateway IP address for each VLAN segment. |
6. Provide Network Access
You must provide the network port access for the Edge Gateway to communicate with the Aviatrix Controller, Aviatrix CoPilot, and the Aviatrix Transit Gateway.
Refer to Aviatrix Edge Gateway Ports and Protocols for the network access requirements.
