Aviatrix Secure Edge on Customer Managed VMware ESXi and KVM Deployment Workflow
This document provides instructions for deploying an Aviatrix Edge Gateway on the customer managed VMware ESXi or an open-source Kernal-based Virtual Machine (KVM).
For an overview of Aviatrix Secure Edge, see Overview of Aviatrix Secure Edge.
650
Before you deploy an Aviatrix Edge Gateway on VMware ESXi or KVM, ensure the prerequisite requirements are complete, see Prerequisites for Aviatrix Secure Edge Deployment on VMware ESXi and KVM.
To deploy Aviatrix Secure Edge, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Aviatrix Secure Edge Deployment on VMware ESXi and KVM). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
The diagram below provides a high-level view of the four-step process for deploying Aviatrix Secure Edge in Aviatrix Controller. You have the option to use either VMware ESXi or an open-source Kernel-based Virtual Machine (KVM) to deploy the Aviatrix Secure Edge VM and attach the ISO file. The ISO file is the equivalent of the Zero-Touch Provisioning (ZTP) token. ZTP allows to remotely deploy and provision network devices at remote locations.
600
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in VMware ESXi and KVM. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
You must have port 443 open to the IP address of the Aviatrix Controller. For the required port access for Edge Gateway deployment, refer to Aviatrix Edge Gateway Ports and Protocols.
  1. Go to Cloud Fabric > Edge > Gateways tab.
  2. Click + Edge Gateway, then provide the following information.
    Parameter Description
    Select edge_admin.
    ZTP File Type
    Select the ZTP file type.
    • For VMware ESXi, select iso.
    • For KVM, select iso or cloud-init.
  3. Configure the WAN, LAN, and Management interfaces.
Configuring the WAN Interface
For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is.
IP Assignment
(optional) A name to identify the WAN interface.
(optional) The Public IP address of the WAN interface.
Configuring the LAN Interface
IP Assignment
VRRP
If you have Virtual Router Redundancy Protocol (VRRP) configured for the LAN router redundancy, set this switch to On.
VRRP Gateway IP
The Virtual IP (VIP) address, when VRRP is enabled.
(optional) The Default Gateway IP for the LAN interface.
(optional) A name to identify the LAN interface.
VLAN Interface
You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration.
This is the interface where the untagged packets are sent.
VRRP Gateway IP
(optional) A name to identify this native VLAN interface.
VLAN Sub-Interfaces
VLAN ID
The VLAN ID.
VLAN Interface CIDR
The VLAN sub-interface IP address.
VRRP Gateway IP
The Default Gateway IP address for this VLAN sub-interface.
Sub-Interface Tag
(optional) A name to identify this VLAN sub-interface.
IP Assignment
Select DHCP or Static, depending on your environment.
This setting cannot be changed after the gateway is created.
Private Network
If the Management interface connection to the Aviatrix Controller is over a private network, set this switch to On.
Leave the setting to Off, if the connection is over the public internet.
Egress CIDR (Optional)
The CIDR range for the egress flow for the Management interface.
edge create error message
The ISO file expires after 24 hours. You cannot download it again and will have to repeat the above steps. You must mount the ISO file to an Edge VM to complete the Edge Gateway registration within 24 hours. See Deploying the Edge Gateway Virtual Machine Instance.
  • Before you can create the highly available Edge Gateway, the primary Edge Gateway must be deployed and its status must be Up.
  • You must have port 443 open to the IP address of the Aviatrix Controller. For the required port access for Edge Gateway deployment, refer to Aviatrix Edge Gateway Ports and Protocols.
To create a secondary (HA) Edge Gateway, follow these steps.
  1. In Aviatrix CoPilot, go to Cloud Fabric > Edge > Gateways tab.
  2. In the table, locate the primary Edge Gateway for which you want to create the HA gateway and click its Edit icon.
  3. In the Edit Edge Gateway dialog box, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
  4. In the Interfaces section, configure the WAN, LAN, and Management interfaces for the secondary (HA) Edge Gateway.
    WAN Interface
    IP Assignment
    LAN Interface
    IP Assignment
    VRRP
    VRRP Gateway IP
    VLAN Interface
    VLAN Sub-Interfaces
    VLAN Interface CIDR
    VLAN configurations are added to the primary Edge Gateway. On the secondary Edge Gateway, some fields are disabled and non-editable, the field value appears when it is selected.
See:
  1. If you have not downloaded the ESXi OVA file, download the file by using the link provided to you by Aviatrix Support. See Download the Aviatrix Secure Edge Image File.
  2. Log in to VMware vSphere Web client to access the ESXi host.
  3. Load the OVA file into the ESXi using vSphere, go to ESXi > Virtual Machines > Create/Register VM.
  4. Select Deploy a virtual machine from an OVF or OVA file and click Next.
  5. Enter a name for the Aviatrix Secure Edge VM and drag the OVA file into the blue pane, then click Next.
    edge_ova_load_file
  6. In the Select storage page, select the storage device where to create the VM instance (the OVA is installed in this instance) and click Next.
  7. In the Deployment options window, enter the Network mappings for WAN, LAN, and MGMT network interfaces and select the Deployment type. (Refer to the pull-down menu or see Virtual Machine CPU and Memory Configurations.)
    edge_ova_deploy_options
  8. Click Next.
  9. In the Ready to complete page, click Finish.
  • The ZTP ISO file can only be used for a single Aviatrix Secure Edge VM instance, and only one time for that instance.
  • The ZTP token expires after 24 hours. If you wait too long to boot up the VM with the attached ISO image, it will not work. In that case, delete the Edge Gateway in the Aviatrix CoPilot and create a new Edge Gateway to receive a new ISO file.
  1. Upload the ISO file downloaded from Aviatrix CoPilot to your VMware datastore.
  2. In vSphere, select the Aviatrix Secure Edge VM you created and click Edit settings.
  3. Select the Virtual Hardware tab.
  4. Next to CD/DVD Drive 1, click the dropdown menu and select Datastore ISO file.
  5. Next to CD/DVD Drive 1, ensure the Connect box is checked and click Save.
    Connect at power on is required when you attach the ISO image to the VM for the first time. If the VM is powered on at the time you attach the ISO image, select the ISO file and save the configuration to make the ISO available to ZTP.
  6. Next to the CD/DVD Media, click Browse, locate the datastore and select the ISO file you uploaded.
    edge_edit_settings
  7. Click Save. ZTP auto-mounts the ISO file and deploys the Edge Gateway on the VM.
  8. Verify the Edge Gateway is Up (see Verifying the Edge Gateway Creation).
KVM Hypervisor does not support configuration of RX/TX queue size during runtime. RX/TX queue size should be configured during Edge Gateway VM bootup. See Enabling Multiqueue virtio-net on KVM.
  1. If you have not downloaded the KVM QCOW2 file, download the file by using the link provided to you by Aviatrix Support. See Download the Aviatrix Secure Edge Image File.
  2. Launch Virtual Machine Manager UI to access the KVM host.
  3. Create a new virtual machine from an existing disk image.
    1. From the File menu, select New virtual machine.
    2. Select the option Import existing disk image.
    3. Click Forward.
      edge-kvm-new-vm
  4. Provide the path to the KVM QCOW2 file and specify the operating system type and version.
    1. Enter the path or use the Browse button to locate the KVM QCOW2 file you previously downloaded.
    2. For OS type, select Linux.
    3. For Version, select Ubuntu 18.04 LTS.
    4. Click Forward.
      edge-kvm-new-vm-2
  5. Enter the memory and CPU settings for the Edge Gateway VM and click Forward.
    edge-kvm-new-vm-3
  6. Enter a name for the Edge Gateway VM and check the Customize configuration before install checkbox, then click Finish.
    edge-kvm-new-vm-4
  7. Add the LAN and MGMT virtual bridge interfaces.
    1. Click Add Hardware.
      edge-kvm-new-vm-5
    2. In Add New Virtual Hardware, select Network from the left pane and add two additional network interfaces for the LAN and MGMT virtual bridges. The virtual bridge for the WAN interface is automatically added as part of the VM image creation.
    3. For Network source, select the name of the virtual bridge for the LAN interface.
    4. For Device model, select virtio.
    5. Repeat steps a and b and add the virtual bridge for the MGMT interface.
      edge-kvm-new-vm-6
  8. Choose the storage device and attach the ISO file to the VM.
    1. In Add New Virtual Hardware, select Storage from the left pane.
    2. Select the option Select or create custom storage.
    3. Click Manage.
    4. Locate and select the KVM iso file which you previously uploaded.
    5. Click Choose Volume.
    6. Click Finish.
      edge-kvm-new-vm-7
  9. Click Begin Installation to create the Edge Gateway VM on the KVM host.
    After the VM is created, ZTP auto-mounts the ISO file and deploys the Edge Gateway on the VM.
  10. Verify the Edge Gateway is Up (see Verifying the Edge Gateway Creation).
Before you attach the Edge Gateway to the Transit Gateway, perform these prerequisite steps.
  1. Ensure Local ASN Number is configured on Edge and Transit Gateway.
  2. If the Edge to Transit Gateway attachment is over public network, you need to update the WAN Public IP on the Edge Gateway.
    2. Locate the Edge Gateway, and click its Edit icon on the right.
    3. In Edit Edge Gateway, scroll to the Interfaces section and click WAN.
    4. In Public IP, click Discover.
      edge discover public ip
    5. Verify the WAN Public IP and click Save.
  • To create a High Performance Encryption mode attachment, make sure the Transit Gateway is created with High Performance Encryption enabled.
  • If you want Jumbo Frame enabled on the Edge Gateway, make sure to enable Jumbo Frame on the Edge Gateway before you attach it to the Transit Gateway.
  2. Locate the Edge Gateway, click the three-dot vertical menu on the right, and select Manage Transit Gateway Attachment.
    edge-attach-edge-to-transit
    Transit Gateway
    Connecting Edge Interfaces
    Attach over Private Network
    • For HPE over private network, setting the number of tunnels count to 0 creates maximum tunnels based on the peering gateway size.
    • For HPE over public network, the number of tunnels count supported range is between 2 and 20.
  3. Click Save.
  1. Navigate to Networking > Connectivity > External Connections (S2C) tab.
  2. Click + External Connection, then provide the following information.
    Connect Local Gateway To
  3. Click + Connection and provide the following information.
    edge external connection
  4. Click Save.
