Managing Views
On the following pages in CoPilot, you can manage the views you have created:
Cloud Fabric > Topology > Overview (New Topology Experience)
Security > Distributed Cloud Firewall > Monitor
Monitor > Performance
You can only manage views if you have already created and saved views on these pages.
On the Overview tab, expand the Views drop-down and select Manage Views. The Manage Views dialog displays.
From here, you can: -
Click the vertical ellipsis  next to the view that you want to use as the default and click Set as Default View. next to the view that you want to use as the default and click Set as Default View.
Click the delete icon  to remove the view. to remove the view.
Filter, download, or search the views.
