Upgrade your Controller via the Controller UI
You can also perform Controller Upgrade and gateway upgrade from the CoPilot UI if your Controller version is 7.1 or later. Go to CoPilot > Settings > Maintenance > Upgrade. See details on: Upgrade your Controller via the Controller UI.
This page instructs on how to perform single-version Controller and Gateway upgrade. For multiple-version Controller and Gateway upgrade, see Multiple-Version Upgrade for Controller and Gateways.
Before Upgrade
Before upgrading your Controller and Gateways, it is highly recommended to check the General Controller and Gateways Upgrade Guidance.
  • Once the Controller upgrade is completed successfully, you proceed to upgrade the Gateways.
Review the Pre-upgrade Tasks
Check and perform all the pre-upgrade tasks. See details in Pre-upgrade Tasks for Controller and Gateways.
Check the Upgrade Checklist
Perform all the items listed in the upgrade checklist. See details in Upgrade Checklist of the Controller and Gateway Upgrade
The following table outlines the steps involved in upgrading the Controller and Gateways when upgrading between different versions.
Perform the following steps to upgrade your Controller to a desired version:
  1. Log in to your Controller UI.
  2. Go to SETTINGS > Maintenance, click Upgrade to open the upgrade panel.
  3. Under the Platform Upgrade section, enter the release number to which you want to upgrade. By default, it will upgrade to the latest version of the current release. Alternatively, you can specify a specific release version.
Upgrade your Gateways
Click PLATFORM UPGRADE to initiate the Controller upgrade process.
Perform the following steps to upgrade your Gateways to a desired version:
  3. Go to the Selective Gateway Upgrade section, choose the gateways you want to upgrade from the dropdown list. However, please note that the system will upgrade the Controller first and then the gateways.
  4. Click Dry Run to check for potential issues.
  5. (Optional) If any issues are reported, address and fix them accordingly.
  6. Click SOFTWARE UPGRADE to upgrade the selected gateways. To perform an image upgrade, click IMAGE UPGRADE.
  7. Wait for the upgrade process to complete and verify that you receive a successful upgrade message.
  • Upgrade HA (High Availability) gateways first, then upgrade primary gateways:
    • To ensure proper continuity and system availability, it is recommended to upgrade HA gateways before upgrading primary gateways. This sequence minimizes any potential disruptions during the upgrade process.
  • After upgrading your HA gateways, upgrade the primary gateways.
Verify your Upgrade
After performing an upgrade, it is important to verify your upgrade status.
