Monitoring Inventory and Status of Managed Resources
This section describes how to check on the inventory and status of your Aviatrix-managed network.
About the CoPilot Dashboard
The Aviatrix CoPilot dashboard page offers a broad perspective on the inventory and health status of your deployment.
For a description of all data shown on the CoPilot Dashboard, see CoPilot Dashboard Page Reference.
In the Health section, the information more critical in determining network health is located to help you quickly determine the overall health of your network. This section provides links to other CoPilot pages where you can analyze the data in more detail.
First displayed in the dashboard is the geographic map showing the approximate location where managed VPC/VNets are located across the globe, along with the approximate location of threats in your network over the past 24 hours as compiled by ThreatIQ, and your blocked countries.
The following elements in the CoPilot Dashboard help you monitor your network’s health:
Card for Gateway Health
Card for Connection Health
Threats list
Card for Detected Intrusions
Card for CoPilot Health
Card for Controller Health
Alerts list
In the Resources section, CoPilot Dashboard shows an inventory of all resources across all clouds in your multicloud network that are managed by Aviatrix Controller.
Inventory cards show the number and DOWN status of each managed resource.
 The count for number of gateways shown on the CoPilot Dashboard reflects the following:
Resource charts show a breakdown of each managed resource on a per cloud basis, the distribution of gateways by type (gateway pairs, not gateway instances), the number of access accounts per cloud, and more.
Monitoring Individual Instances for Gateways
The count for the number of gateways shown on the CoPilot Dashboard reflect gateways that currently exist in your Aviatrix-managed networks.
If you are troubleshooting a network problem and want to see a list of all gateway instances, you can open the CoPilot > Cloud Fabric > Gateways page, and from the applicable gateway view (Transit, Spoke, or Specialty), locate the table row of the desired gateway.
On the respective Gateway pages, you can click the ellipsis button
 and select Gateway Diagnostics to run diagnostics from any gateway instance.
