The Aviatrix Hybrid Cloud Edge solution supports customized SNAT and DNAT for the use case where the cloud service provider (CSP) network CIDR overlaps with the on-premises network CIDR. The customized SNAT and DNAT apply to HPE-enabled and HPE-disabled Edge Spoke gateways.
- Single IP and Customized SNAT on Edge Spoke Gateway - For network traffic initiated from the edge location towards the CSP.
- DNAT on Edge Spoke Gateway - For network traffic initiated from the edge location towards Transit Gateway in cloud or CSP.
Customized SNAT on Edge Spoke Gateway is not supported when VLAN segmentation is also configured in the same network domain.
This diagram shows overlapping CSP and on-premises network CIDRs.
- Create a mapping of the Real CIDR to Virtual CIDR for both the cloud instances and on-premises hosts or workloads. For example:
| Network | Real CIDR | Virtual CIDR |
| Cloud workload | 10.3.0.86/32 | 10.203.0.86/32 |
| On-prem workload | 10.3.0.85/32 | 10.103.0.85/32 |
Configure DNAT on Edge Spoke Gateway for traffic initiated from on-premises to cloud.
a. In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
b. Click Spoke Gateways
c. Select the Edge Spoke Gateway for which you want to enable DNAT.
d. In the Edge Spoke Gateway’s Settings tab, expand the Network Address Translation (NAT) section.
e. Set the Destination NAT toggle to On.
f. In Destination NAT, from the Instance dropdown menu, select the Edge Spoke Gateway.
g. Click + Rule and provide the following information.
| Field | Description |
| Instance | From the dropdown list, select the Edge Gateway instance. |
| Src CIDR | Enter 10.3.0.85/32. |
| Dst CIDR | Enter 10.203.0.86/32 (the virtual IP of the cloud instance). |
| Connection | From the dropdown list, select the connection which reflects the connection to the Transit Gateway. |
| Mark | (Optional) Enter a unique value. Value should be between 65535 - 99999. |
| DNAT IP | Enter 10.3.0.86 (cloud instance). |
- Configure a Manual BGP Advertised CIDR List to advertise the DNAT virtual IP from the Edge Spoke Gateway to on-premises via BGP.
a. In the Edge Spoke Gateway’s Settings tab, expand the Border Gateway Protocol (BGP) section.
b. In Manual BGP Advertised CIDR List, enter the following information.
| Advertised CIDRs (Per Gateway) | Leave this blank. |
| Connection | From the dropdown menu, select the connection to the on-prem BGP peer. |
| Advertised CIDRs (Per Connection) | Enter 10.203.0.86/32 (the virtual IP of the cloud instance) |
- Configure SNAT on the Edge Spoke Gateway for traffic initiated from cloud to on-premises.
a. In the Edge Gateway’s Settings tab, expand the Network Address Translation (NAT) section.
b. Click the Source NAT switch to On, then click Customized SNAT.
c. From the Instance dropdown menu, select the Edge Spoke Gateway.
d. Click + Rule and provide the following information.
| Connection | Select the output connection where the rule will apply. |
| Mark | Enter the value that was defined in the DNAT settings.
Specifies a TCP session where rule applies. |
| SNAT IP | Enter 10.103.0.85 (virtual IP of the on-prem host). |
