- For encrypted connectivity across network service providers (NSPs), such as Equinix and Megaport, and Datacenter fabric, create an Edge Transit Gateway to Edge Transit Gateway attachment.
- For encrypted connectivity to cloud, create an Edge Transit Gateway to a Transit Gateway attachment.
- For encrypted connectivity to remote site or on-premises, create an Edge Transit Gateway to an Edge Spoke Gateway attachment.
Attach an Edge Transit Gateway to Edge Transit Gateway
If you want to use Jumbo Frames for the attachment peering connection between
the Edge Gateways, make sure to enable Jumbo Frames on the Edge Gateways
before you create the attachment.
- In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways > Transit Gateways tab.
Locate the Edge Transit Gateway to which you want to attach an Edge Transit
Gateway, then click the Manage Gateway Attachments icon
on the right side of the row.
In Manage Gateway Attachments > Transit Gateway tab, click +
Attachment and provide the following information.
In the Advanced section, enter or select the following:
- To attach the Edge Transit Gateway to another Edge Transit Gateway, click + Attachment again and provide the required information. You can attach an Edge Transit Gateway to multiple Edge Transit Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
- Click Save.
Attach an Edge Transit Gateway to Transit Gateway
To create a High Performance Encryption (HPE) attachment, make sure the
Transit Gateway in the cloud is created with HPE enabled.
If you want to use Jumbo Frames for the attachment, make sure to enable Jumbo
Frames on the Edge Transit Gateway and the Transit Gateway in the cloud before
Locate the Edge Transit Gateway to which you want to attach the Transit
- To attach the Edge Transit Gateway to another Transit Gateway, click + Attachment again and provide the required information. You can attach an Edge Transit Gateway to multiple Transit Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
- Click Save.
Attach an Edge Transit Gateway to Edge Spoke Gateway
Locate the Edge Transit Gateway to which you want to attach the Edge Spoke
In Manage Gateway Attachments > Spoke Gateway tab, click + Attachment
- To attach the Edge Transit Gateway to another Edge Spoke Gateway, click + Attachment again and provide the required information. You can attach an Edge Transit Gateway to multiple Spoke Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
- Click Save.
