Configuration Workflow
To build an external connection (S2C) between an Edge gateway and an external remote device, you need to configure one side of the tunnel connection on the Edge gateway and the other side of the tunnel connection on the remote device. To create an external connection:- Configure the tunnel on the Edge gateway.
- Download the Edge gateway tunnel configuration file.
- Configure the tunnel on the remote device.
- Verify the connection is up.
Configure the Tunnel on the Edge Gateway
For BGP connection to the remote device, configure the tunnel using one of the options below:Download an External Connection Configuration
If you are connecting an Aviatrix gateway and an on-premises router or firewall, Aviatrix can generate a configuration file that you can apply to your remote router or firewall. The configuration file contains the Aviatrix gateway tunnel details, such as the Public IPv4 and IPv6 addresses, VPC/VNet CIDR, pre-shared key, and encryption algorithm. You can download the configuration file and then import the details to your remote router or firewall to configure the other end of the VPN tunnel. After creating an external connection, to download an external connection configuration:- In Aviatrix CoPilot, go to Networking > Connectivity > External Connections (S2C) tab.
On the External Connections (S2C) tab, locate the connection you created and
click the vertical ellipsis
icon on the right side of the row.
Select the following values:
- Vendor: Select your remote site device.
- Select Generic for anything that is not an Aviatrix gateway.
- Select Aviatrix, if you are connecting two Aviatrix gateways.
- Platform and Software:
- If you selected a Generic vendor, the Platform field is populated as Generic, and the Software field is populated with Vendor Independent.
- If you selected the Aviatrix vendor, the Platform field is populated with UCC, and the Software version is 1.0.
- If you selected a specific hardware vendor (such as Cisco), select from the available platforms belonging to that vendor are displayed in the Platform field (ISR, ASR, and CSR are for Cisco routers), and the Software field is populated with the related software version.
- Click Download.
Configure the Tunnel on the Remote Device
On the external remote device, configure the other end of the tunnel by using the Edge gateway’s connection details provided in the configuration file which you downloaded. If you need to download the configuration file, refer to Download the External Connection Configuration.Verify the Connection Status
To verify the connection status:- In CoPilot, go to Diagnostics > Cloud Routes > External Connections tab.
- In the table, locate the connection that you created. The Status should be Established.
Disconnect the External Connection
To disconnect an external connection:- In Aviatrix CoPilot, go to Networking > Connectivity > External Connections (S2C) tab.
- In the table, locate the external connection and click the Delete icon
- To confirm that you want to delete the external connection, click Delete.
