Static Route-Based External Connection (Mapped)
This document describes the workflow to create a Static Route-Based (Mapped) connection.
In this document, Local Gateway refers to the Aviatrix gateway that you want to connect to a remote device.
Supported Gateways
  • Spoke Gateway that is not BGP enabled in AWS, Azure, and GCP
  • Speciality Gateway (not applicable to Public Subnet Filtering Gateway)
External Connection Settings
For information about the options that you can configure for a Site2Cloud (S2C) external connection, refer to About External Connection Settings.
Workflow
When setting up a Static Route-Based Mapped external connection on Aviatrix Gateways, NAT Traversal (NAT-T) must be enabled on the remote (non-Aviatrix) device. If a NAT is present between peers, the connection switches to UDP port 4500, using UDP encapsulated ESP (Encapsulating Security Payload). Disabling NAT-T on the remote device can lead to connection failures.
If NAT-T is disabled and NAT exists in the network path, the IPsec tunnel may not establish or function properly.
It is recommended to configure NAT-T explicitly on remote VPN devices to ensure reliable IPsec tunnel connections with Aviatrix gateways.
To set up a Static Route-Based (Mapped) external connection:
  2. From the + External Connection dropdown menu, select External Device.
  3. In Create External Connection to External Device, provide the following information:
    Field Description
    A name for the connection.
    Type
    Select Static Routing over IPsec
    Static Routing Type
    Select Mapped NAT
    Custom Mapped
    Leave Custom Mapped toggle Off.
    The Local Gateway that you want to connect to a remote device.
    Real Local Subnet CIDR(s)
    Specify a list of the source network CIDRs, seperated by comma, that will be encrypted. If left blank, the full CIDR is used. If you enter a value, make sure you include the VPC/VNet as well. These Local Subnets are advertised to Remote Subnets that the connection can reach. Examples of real local subnets are 172.16.1.0/24, 172.16.2.0/24.
    If the Local Subnet CIDR(s) is outside of gateway VPC/VNet, you need to open the gateway inbound security groups to allow the Local Subnet network CIDR ranges.
    If you enter multiple real subnets, you must configure an equal number of virtual subnets. One-to-one mapping is supported if both sides are configured properly.
    Virtual Local Subnet CIDR(s)
    Specify a list of virtual local network CIDRs, separated by comma, that map to the real local subnet (for example, for the real local subnet CIDRs listed above, you can have these virtual local subnets: 192.168.7.0/24, 192.168.8.0/24).
    Remote Device Type
    The remote device type.
    • Generic - Use this option for most third-party routers and firewalls.
    • Aviatrix - When terminating on Aviatrix cloud gateways or for peering Controllers in different networks.
    Any other remote device types listed are only valid with Controller version 6.7 or lower. If using a higher Controller version, only select Generic or Aviatrix.
    Real Remote Subnet CIDR(s)
    Specify a list of the destination network CIDRs, separated by comma, that will be encrypted (for example, 10.10.1.0/24, 10.10.2.0/24).
    Virtual Remote Subnet CIDR(s)
    Specify a list of virtual remote network CIDRs, separated by comma, that map to the real remote subnet (for example, for the real CIDRs listed above, you can have these virtual remote subnets: 192.168.1.0/24, 192.168.2.0/24).
  4. In the IPsec Configuration section, provide the following information:
    Field Description
    Attach Over
    The underlying infrastructure of your network.
    • Private Network: Your underlying infrastructure is a private network, such as AWS Direct Connect and Azure ExpressRoute. When this option is selected, BGP over IPsec runs over private IP addresses.
    • Public Network: Your underlying infrastructure is a public network or the internet. When this option is selected, BGP over IPsec runs over public IP addresses.
    Algorithms
    The encryption algorithm and protocol to use for authenticating the communication between the Local gateway and the remote device.
    • Default: Uses the Aviatrix-supported encryption algorithm default values.
    • Custom: Allows you to modify any of the fields defined below.
      • Phase 1 Authentication
      • Phase 1 DH Groups
      • Phase 1 Encryption
      • Phase 2 Authentication
      • Phase 2 DH Groups
      • Phase 2 Encryption
    Internet Key Exchange
    Internet Key Exchange (IKE) is the protocol used for authentication and encryption of packets between the Aviatrix gateway and the on-premises device.
    • IKEv1: Connects to the remote site using IKEv1 protocol.
      If you configure IKEv1 in a connection that uses certificate-based authentication and is connecting to another Aviatrix device, you must add the intermediate CAs in addition to the root CA. When an intermediate CA is renewed and re-authentication is attempted, the connection will go down until you add the new certificate.
    • IKEv2: Connects to the remote site using IKEv2 protocol. This is the recommended protocol.
  5. In the Authentication section, provide the following information:
    Field Description
    Authentication Method
    The authentication method to use for the connection.
    • Pre-Shared Key: If you select Pre-Shared Key (PSK) authentication, you can provide the PSK when prompted (this is optional).
    • Certificate: If you select certificate-based authentication, in the Remote CA Certificate field, select the certificate you uploaded from your remote device.
  6. In the Tunnel Configuration section, provide the following information:
    Field Description
    Single IP High Availability
    Enable this setting to set up High Availability (HA) instances for each new connection that can go up if the primary instance goes down. When active, each standby instance will use the same IP address as the remote connection.
    Remote Device IP
    The remote device’s interface IP address.
    Pre-Shared Key (Optional)
    If Pre-Shared Key authentication is selected, enter the Pre-Shared Key configured on the remote device.
    If a Pre-Shared Key is not specified, the system auto-generates a key.
    Remote Identifier SAN
    If Certificate-based authentication is selected, enter the Subject Alternative Name(SAN) of the remote CA Certificate.
  7. Click Save.
    The new static route-based external connection appears in the table.
