Deploy a HA Edge Transit Gateway (Equinix)
To create the secondary HA Edge Transit Gateway, first you need to set the high availability mode for the primary Edge Transit Gateway, then configure the secondary HA gateway settings. The workflow below guides you through these steps.
Step1: Set the Primary Edge Gateway High Availability Mode
Click Transit Gateways.
In the table, locate the primary Edge Transit Gateway for which you want to create the HA gateway and click its Edit icon.
In Gateway Configuration, from the High Availability dropdown menu, select Active-Active mode.
Click Next and configure the gateway interfaces.
Step 2: Configure the Secondary Edge Gateway Interfaces
In Interface Configuration, configure the WAN and Management interfaces for the secondary Edge Gateway.
Configure the WAN Interfaces
To configure the secondary Edge Gateway’s WAN interfaces:
In Interface Configuration, provide the following information.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP) or other Edge Transit Gateways. Add an interface per CSP underlay (such as Direct Connect or Express Route).
Interface Secondary CIDRs
Password (optional)
The MD5 authentication key.
To configure the secondary Edge Transit Gateway Management interface:
In Interface Configuration, click MGMT.
Leave the default settings and click Next.
Leave the Private Network setting to Off. In Equinix, the MGMT interface of the Edge Transit Gateway is assigned the public IP address that is allocated by Equinix.
Step 3: Interface Mapping
Field  |
Description  |
Interface  |
The Edge Gateway’s logical interface name.  |
Primary Gateway Ethernet Interface  |
The primary Edge Gateway’s Linux interface name.  |
Secondary Gateway Ethernet Interface  |
The secondary (HA) Edge Gateway’s Linux interface name. The secondary gateway interface mappings are shown only when high availability is configured for the primary Edge Gateway.  |
Backup Peering
In Backup Peering:
Select a WAN interface to use to establish the attachment peering between the primary and HA Edge Transit Gateway.
Click Done to create the ZTP cloud-init image file. CoPilot downloads the ZTP cloud-init file to your downloads folder.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on your Equinix platform within that time. You will not be able to download the cloud-init file again and will have to recreate a new file.
