Creating the ZTP Cloud-Init for the Primary Edge Transit Gateway (Equinix)
The Edge Gateway cloud-init ZTP file is used to provision the Edge Gateway virtual machine and create the Edge Gateway in Equinix Fabric.
To create the primary Edge Transit Gateway cloud-init ZTP file, follow these steps.
Step 1: Gateway Configuration
Click Transit Gateways, then click + Transit Gateway and provide the following information.
A name for the Edge Gateway.
The platform account where you want to deploy the Edge gateway.
You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. See Setting up Accounts for Edge Platforms.
Identifies the edge location.
You can select an existing name or enter a new name for the edge location. See Edge site.
ZTP File Type
This is set to cloud-init.
High Availability is set to Off for the primary Edge gateway.
You can turn High Availability to On after the primary Edge gateway is created.
By default, an Edge Transit Gateway has two interfaces: one WAN interface on eth0, and one Management interface on eth2. You can configure multiple WAN interfaces on the Edge Gateway, as needed. A maximum of nine WAN interfaces is supported per Edge gateway.
Configure the WAN Interface
Edge Transit Gateway on the Equinix Network Edge supports up to nine WAN interfaces.
In Interface Configuration, click + WAN Interface and provide the following information.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP) or other Edge Transit Gateways. Add an interface per CSP underlay (such as Direct Connect or Express Route).
Interface Secondary CIDRs
Password (optional)
The MD5 authentication key.
In Gateway Configuration, enter the Local AS Number of the local Edge Gateway.
In Interface Configuration, click MGMT > + MGMT Interface.
Leave the Private Network setting to Off. In Equinix, the MGMT interface of the Edge Transit Gateway is assigned the public IP address that is allocated by Equinix.
Step 3: Interface Mapping
Field  |
Description  |
Interface  |
The Edge Gateway’s logical interface name.  |
Primary Gateway Ethernet Interface  |
The primary Edge Gateway’s Linux interface name.  |
Secondary Gateway Ethernet Interface  |
The secondary (HA) Edge Gateway’s Linux interface name. The secondary gateway interface mappings are shown only when high availability is configured for the primary Edge Gateway.  |
Click Done to create the ZTP cloud-init image file. CoPilot downloads the ZTP cloud-init file to your downloads folder.
 The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on your Equinix platform within that time. You will not be able to download the cloud-init file again and will have to recreate a new file.  |
